Old 10-02-2010, 02:24 AM   #1
tthornt
tthornt's Avatar
Third Brake Light
Hey all - I'm trying to add a third brake light (Mounted on top of the cab) on my 1983 C10. Any suggestions as to how the third light (has two wires) should be wired?
Thanks,
Tony
Country; LIKE A ROCK
All that I am, I owe
62SWB-STEP
83SWB
86LWB
tthornt is offline   Reply With Quote
Old 10-02-2010, 09:04 AM   #2
Pop's C-10
Pop's C-10's Avatar
Re: Third Brake Light
astro or tahoe 3rd brake light looks like a good choice for a sway to me
Pop's C-10 is offline   Reply With Quote
Old 10-02-2010, 11:22 AM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Run the powered wire directly to to your brake light switch. and ground out the other lead. This way it won't flash with your turn signal the way most aftermarket installs do that I've seen.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-02-2010, 02:52 PM   #4
HumbleChevyBuddy
HumbleChevyBuddy's Avatar
The first thing you want to check is your taillights. If yours doesn't have separate brake/turn lamps, then you will have to use a logic circuit. I want to say the 83 does have separate lamps though, so you should be ok. Here is a wiring diagram from another thread for your year model:
http://www.73-87chevytrucks.com/tech...s_rr_light.jpg
I installed an aftermarket third brake light license frame on my 1980 C10 with 3 wires and it was a PITA, but mine does not have separate lamps so I had to use a logic circuit on mine. Here is a diagram of how I created one with two relays. I connected mine to where the third brake light flashes with the turn signals, but like I said if yours has separate bulbs you should be ok. Just figure out which wire is the brake light and connect the power of the third brake light to that and ground the other wire. I hope this helps.
HumbleChevyBuddy is offline   Reply With Quote
Old 10-02-2010, 11:42 PM   #5
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Thats how I did it.
http://67-72chevytrucks.com/vboard/s...d.php?t=361457
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 11-18-2012, 07:06 PM   #6
1964Chevy
1964Chevy's Avatar
I just ran another wire from my brake light wire at the brake, took about 15 minutes. Thanks for the how to BLE 'BURBAN.
1964Chevy is offline   Reply With Quote
Old 11-19-2012, 02:36 AM   #7
BLE 'BURBAN
Anytime! And welcome to the board!!!
Old 11-19-2012, 09:52 AM   #8
bk2life
that is the correct way to do it.
bk2life is offline   Reply With Quote
Old 11-21-2012, 09:55 AM   #9
DBLSPRT68
DBLSPRT68's Avatar
I installed a ford f150/250 third brake light. It fit really well, and has the brake light with bed lights. I ran a wire from the brake switch to the light. You also have to cut out the mounting hole some..... pics.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
