Old 10-23-2010, 08:01 PM   #1
realsteelGM
realsteelGM's Avatar
Wink engine gasping on fresh break-in
engine is firing at high r.p.m. but gasping in between changing gears at low rpm, set timing in variety of places. Could this be a bad plug or wire or something I am not knowing about? This is a 283 with vortec heads and 2116 eddy intake and 500 cfm eddy carb all new.
"gotta love something that works without a computer"
realsteelGM is offline   Reply With Quote
Old 10-23-2010, 08:04 PM   #2
69 longhorn
Re: engine gasping on fresh break-in
What do you run for camshaft, & what is you IGN total set at?
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 10-24-2010, 12:31 AM   #3
realsteelGM
My cam is a mild cam and adequate for the 283 set-up, it is .420/.443 lift 204/214 duration @ .050
I have not all the correct timing degrees figured out yet. Just experimenting with timing light and frequency.
Old 10-24-2010, 12:53 AM   #4
69 longhorn
The cam sounds pretty mild, if you are running HEI dist, I would try to set the initial around 12 -14 btdc (just to get in the ball park). A vac guage will tell a lot,you should run 17-18 vac @ idle(steady)....if not, check for air leaks. crazyAl
Old 10-24-2010, 11:41 AM   #5
realsteelGM
I'll pick up a vac gauge and find out what the total advance adds up to, there is no timing written in stone for this engine set up. Looks like vacuum and setting up a stationary timing mark will be necessary.
Old 10-24-2010, 12:02 PM   #6
Lee H
Lee H's Avatar
Your engine will run just fine with 16-18 degrees initial and 36 total all in by 2500. Add about 16 degrees vacuum advance, hooked to manifold vacuum, for a total of 52. This timing will work for just about any small block Chevy with a mild to performance build. This will lead to a crisp throttle response and reduced engine temps. If any pinging occurs just back of 1 degree until it no longer pings. Did you verify TDC with the timing mark when you put together your motor? As far as gasping, what does that mean?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
