Alright Alright Alright
Carrier Bearing Going Out
Lately, I have noticed a squeaking coming from the back of my truck upon acceleration. I also noticed that there was a slight vibration on the highway the first time since the squeaking. Does the bearing need to be greased through a fitting? What do you think?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
Re: Carrier Bearing Going Out
You probably have a U-joint going bad.
Firefighter
Sounds like your U-joint is bad.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Shake the driveline See if you've got movement
How can I tell if the u joints are bad?
