Old 11-07-2010, 07:18 PM   #1
68anniversary
Cooling line question
I'm converting to an auto trans and I need to know how the trans lines run. Trans is a 350TH with 350V8. I was looking at them and assuming they both went to the inside of the engine mount? Are there any clips?
68anniversary is offline   Reply With Quote
Old 11-07-2010, 07:26 PM   #2
JimKshortstep4x4
Re: Cooling line question
The lines route around the starter and beside the oil pan before going up to the radiator. There is one clip attached by a stud (which is used for one the oil pan bolts) that hold both lines.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-07-2010, 07:32 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Yes, there's one big clip on the oil pan. The two small ones are for the plug wires.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-07-2010, 10:02 PM   #4
68anniversary
Great, exactly what I needed to know. Thanks!
