Old 11-10-2010, 07:39 PM   #1
Fat Mike
Fat Mike's Avatar
Airbags On A G-body
When installing airbags on a g-body frame do you have to use a spacer between the airbag and the upper frame? Also how much of a spacer do you need?
Fat Mike is offline   Reply With Quote
Old 11-10-2010, 09:36 PM   #2
jjjmm56
jjjmm56's Avatar
Re: Airbags On A G-body
Mike search for, My Project 56 chevy 1300. He gives a real good writeup on his project. I followed alot of the things he did and it worked out great. Good luck!
jjjmm56 is offline   Reply With Quote
Old 11-10-2010, 10:12 PM   #3
youngrodder
youngrodder's Avatar
Fat Mike-
Are you talking about the front or the rear? G-body kit was purchased from Air ride. I can measure the spacers if you indicate which ones you were referring to.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-10-2010, 10:54 PM   #4
Fat Mike
Fat Mike's Avatar
I am referring to the front bags and I am using firestone 2600. I know you have to trim the housing out and make sure that the bag does not rub but I think the part I am talking about is the airbag upper cup.
Old 11-11-2010, 09:48 AM   #5
youngrodder
On mine uses upper cups. I think that they are about 4" in height. You might be able to check the Air ride site to see if it lists any dimensions because it will be hard for me to measure mine with it up in the frame. They sold it as a g-body kit.
Marc
Old 11-11-2010, 09:55 AM   #6
Fat Mike
Fat Mike's Avatar
I found out that they are 4" and they did give dimension on them. With the help of Thomas at Aftershock Customs, alocal shop, we built are own.
Old 11-11-2010, 10:18 AM   #7
youngrodder
I made a pretty good guess, since it has been quite sometime since I saw mine out.
They look pretty easy to make once you know what size to make them.
Good luck
Marc
Old 11-11-2010, 11:01 AM   #8
Fat Mike
Fat Mike's Avatar
Thank you very much for the info!
