help me find a radiator
im looking for a new radiator for my 63 chevy 350 motor/350 turbo trans. i dont know to much about radiators so i dont know what kind i looking for,or size thanks steve
Re: help me find a radiator
can someone move me to the 60-66
Old Skool Club
![]() Join Date: Jun 2001
I went to a radiator shop and ordered one for my '69. People buy them from parts stores. If you're looking for a used radiator that will fit, get out your tape measure and start there.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
i had a chrysler radiator in the truck for years but it had to go. where is the best place to order a new one
ill check my local radiator shop........thanks ray
try googlein your area for a rad supplier// around here 1 800 radiator is a great place to get one a phone call and the rad is at your door in 2days at real good price compared to local parts store
![]() Join Date: Oct 2007
Modine makes a nice radiator for 60-66 with V8, and it has passages for your transmission cooler. It's a direct bolt-in, but you need to get a new upper radiator mount from a V8 truck, which is a bit different than the 6-cyl upper mount.
The V8 radiator sits up higher...it is wider, so sits on top of the frame rails instead of sliding down in between. |
![]() Join Date: Sep 2006
You can even go aluminum if you want. They sell them on E bay. http://motors.shop.ebay.com/eBay-Mot...0.l1313&_rdc=1 . If you get one.. Choose wisely
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
anybody know about this setup ,and would i need a 2,3,or4 row thanks
Senior Enthusiast
Here's an earlier thread with input on the Champion radiator:
http://67-72chevytrucks.com/vboard/s...mpion+radiator |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I have the champion in my truck, works fine, fits fine. No problems at all.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Who Me?
A 3 row should be plenty.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#13 |
It's Better With Nitro
Here's a photo of mine after I fabricated a shroud for my dual fans...I did move one of the lower saddles over a bit to clear the trans cooler port. My buddy in Phoenix is currently running one in his '66 with a performance 406 ci SBC and air conditioning that he drives everyday and has no issues in the AZ heat with the AC on.
#14 |
three row
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 11-16-2010 at 09:32 PM. |
#15 | |
Rollin' Old Skool
i just recently ordered a Modine for my VW Cabriolet daily driver...i got it at Advance Auto Parts...they were running a 20% off special for online ordered radiators, but i'm not sure if one is available there for your truck....the Modine for my VW fit great with no issues at all or here: http://memphis.craigslist.org/pts/2051821525.html talk him down on the price |
#16 |
i think im going with the champion 3 row with the fan. thanks for your guys help
#17 |
![]() Join Date: Oct 2006
chief used a summit rad here is the link
http://67-72chevytrucks.com/vboard/s...or#post2476347
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#18 |
I have that summit radiator for my truck, only a bigger one. PITA to mock up. I am acually not going to use it and get one that just fits.
#19 |
You might look at this thread, it has some more options.
http://67-72chevytrucks.com/vboard/s...05#post3929405
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
#20 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I see some advertised as 60-62, and some 60-66, and some 63-66.
Isn't it the same radiator? Or atleast; won't they all fit?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#21 |
Senior Enthusiast
They will probably all fit, but the 60-62's I've seen all bolt to the grille support with side flanges, while the later versions rest in a saddle at the bottom and have a clamp holding the top tank in place. I'm not sure what year the design change was implemented.
#22 |
Thanks,
Now that I think about it, I'm pretty sure I had a 62 in my 65.
