Old 11-19-2010, 09:35 AM   #1
bw4sale
bw4sale's Avatar
Two tanks - one compressor
Can I run two 3 gallon tanks and only one compressor? I'm thinking of going this route so that I can put the tanks under the bed instead of in the bed. How would you plumb it? Just run a line between the two tanks to connect them with the compressor connected to one of them or split the line coming from the compressor and send a feed to both tanks?
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 11-19-2010, 10:05 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Two tanks - one compressor
It depends on how your bungs are arranged. On my 77 we have the inlet going in one end of the 1st tank and the outlet on the same end of the 2nd tank. The tanks are married on the other end.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-19-2010, 10:14 AM   #3
bw4sale
bw4sale's Avatar
My compressor will probably be mounted somewhere around where yours is, but my tanks will be outside the framerails on each side. I would rather send a feed to both tanks rather than tie them together, but didn't know if this would cause any issues.
BRENT
Old 11-19-2010, 01:20 PM   #4
jimmydean
jimmydean's Avatar
I would think you would want your feed line as short as possible, so it's best to tie the tanks together. You could still do the tanks outside, just mount the compressor near one of them, then run a line to the other.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-19-2010, 03:47 PM   #5
dznucks
dznucks's Avatar
I am running two 3 gal tanks and a single compressor. i ran mine like n2trux describes, but my tanks are on either side of the frame rails, in front of the rear tires. Compressor is in back passenger corner tucked up under the bed.
What type of valve set up do you plan to run? seperate valves or valve block?
If you run a dual feed, your doubling you chances that something could happen to that feed line and take out your whole system. ie, road debris or something. I ran a single 3/8" hard line from the compressor to the first tank. then ran 1/2" hard line from tank to tank and then from the second tank to my accuair valve block. The larger 1/2" line allows more volume of air to be delivered.
One thing to remember about pressure is that the pressure in a system is equal everywhere in the system at all times. So your not gaining anything by using a dual feed, just adding risk.
dznucks is offline   Reply With Quote
Old 11-19-2010, 05:14 PM   #6
bw4sale
bw4sale's Avatar
That makes sense about the risk. Hadn't even thought of that.
I'm going with the accuair VU4 block (don't have it yet). Here's what I was thinking. If I run a feed to each tank, then I can run a line from each tank to the block since it has 2 air inputs. I believe the 3 gal. tanks have just two ports plus a small port for a gauge. Do I gain anything by running two feeds to the block? The pressures the same but what about the volume?
BRENT
Old 11-21-2010, 03:46 PM   #7
bw4sale
bw4sale's Avatar
Anyone else have any thoughts?
BRENT
Old 11-21-2010, 07:33 PM   #8
dznucks
dznucks's Avatar
Yes you would gain from using both inlets on the accuair block.
The block used 3/8" ports. I ran a single 1/2" hard line to the block then split it into two 3/8 lines to feed both ports. Its lighting quick when you raise the truck.
in this link you can get the idea for how i ran my lines. i can get a good picture of whats inside the black box. both the valve and ecu are inside. i wanted to keep all of that stuff protected from debris and water.
http://67-72chevytrucks.com/vboard/s...d.php?t=399396
Old 11-21-2010, 08:01 PM   #9
mario1128
how about on the feedline to each tank have a checkvalve to only let air in in case the main line or other tank goes bad it wont empty both tanks.
72 chevy former 1ton converted to 1/2 ton roller 350 engine , turbo 350 and a 12 bolt on leafsprings with a flip and drop springs
mario1128 is offline   Reply With Quote
Old 11-21-2010, 08:19 PM   #10
dznucks
dznucks's Avatar
very good point....i forgot to mention.
The Viair compressor has a check valve at the end of the pigtail. With the Accuair valve you will want to put a check valve between the second tank and the valve. when the pressure in the tanks drops below the pressure in the bags, the valve will back flow and the whole system will drain, bags and all.
Doing this will seal your air supply system in the event of compressor failure or valve malfunction. I designed my system with preventing failure in mind.
Old 11-21-2010, 11:27 PM   #11
bw4sale
bw4sale's Avatar
With the Accuair valve you will want to put a check valve between the second tank and the valve. when the pressure in the tanks drops below the pressure in the bags, the valve will bag flow and the whole system will drain, bags and all.
Good idea. Hadn't thought about that.
BRENT
