Old 11-23-2010, 12:15 AM   #1
Andice
Andice's Avatar
Punched Holes in Tranny Hump
My '64 Fenderside has two punched holes in the upper portion of the transmission hump similar to the holes depicted in the attached photo. It seems like i have seen these holes punched in other trucks on this forum. Why would these holes be there? Will I regret patching them?
Andice is offline   Reply With Quote
Old 11-23-2010, 01:45 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Punched Holes in Tranny Hump
A guess , but they might be to geat at those 2 upper bolts easier bellhousing/motor.
those 2 are the hardest to get a good bite on.
Old 11-23-2010, 03:40 AM   #3
padresag
theoretically one doesn't need to undo those bolts on a std trans in the truck as everything in the flywheel clutch area is accessible through the bottom of the b/housing and if it is an a/t a 24" ext and a 9/16 impact flex socket will get up in there nicely
ron
padresag is offline   Reply With Quote
Old 11-23-2010, 07:16 PM   #4
raycow
If you have a stock bellhousing (cast iron and open on the bottom) there is no real need for those holes. If you have an aluminum full-circle bellhousing, you might want to leave them there.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-23-2010, 07:35 PM   #5
rideblue00
rideblue00's Avatar
Im thinking it looks like a car 4 speed setup. Maybe it had 2 different car 4 speed setups over time.
rideblue00 is offline   Reply With Quote
Old 11-23-2010, 09:30 PM   #6
DPowers
DPowers's Avatar
Bullet holes?
DPowers is offline   Reply With Quote
Old 12-09-2010, 04:49 PM   #7
mikie 1954
My 64 gmc has the same holes, they are drane holes for aftermarket ac underdash unit. There are 2 drane tubes one on each side of unit. MIKE
mikie 1954 is offline   Reply With Quote
Old 12-09-2010, 05:46 PM   #8
SCOTI
SCOTI's Avatar
x2. My 64 (the one I had back in high school) had a dealer installed under-dash a/c set-up. It had 2 drain tubes that were poked through the floor carpet & dumped condensate out the tunnel.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-09-2010, 07:04 PM   #9
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Originally Posted by DPowers View Post
Bullet holes?
Maybe so
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-09-2010, 07:13 PM   #10
gulffishin
gulffishin's Avatar
I would plug them with rubber grommets. Then you can keep the cold air out and be able to access the bolts if needed.
gulffishin is offline   Reply With Quote
Old 12-09-2010, 07:20 PM   #11
markeb01
Senior Enthusiast
markeb01's Avatar
That makes a lot of sense. That's how they installed aftermarket smog controls on old engines back in the early 60's. A hole would be drilled in the intake manifold (while it was bolted on the engine!), and then a lead hose fitting was pushed into the hole. The valve cover and air cleaner didn't need a drill because a fine precision hole (?) could be pounded in with a punch and hammer looking just like the ones in the floor pan photo. Hoses were attached and the car was now smog legal. Of course the engine failed shortly thereafter because of all the filings dropped in the engine and all the new found vacuum leaks.
Old 12-10-2010, 08:53 PM   #12
mikie 1954
I still have the ac unit in storeage. I could get the make and model # if you want to check it further.
