Old 11-28-2010, 01:01 AM   #1
kev63rod
kev63rod's Avatar
brake lockout?
hi just bought a 64 chevy 4x4 and found this underneath. was wondering if this is a lockout to lock the front brakes up for burnouts or what?
here is a pic of the truck. not the best as it was dark outside. 70's axle up front with dics brakes. under the hood it has power steering, power brakes. looks to be a 70'ish 350 motor with hei ingnition. newer auto trans/trans case. inside it has a 70's column and brand new carpet. also came with a new windshield and all the weather stripping for the cab along with a boxfull of crome parts for the grill and tailights. also has a new intake and gaskets along with a used holly 4 barrel laying on the floor. havent heard it run but finnally got it to crank after going through the wire harness. (wire nuts, butt splices, melted wires, and all that fun stuff) i think im not getting spark but havent had a chance to check. it didnt sound to good when it was cranking over though. had some kinda noise in the frontend of the motor. maybe timing chain. the kid i bought it from said he had it running, but i have my doubts.
blessed are they that expect nothing, for they shall not be dissapointed
kev63rod is offline   Reply With Quote
Old 11-28-2010, 01:18 AM   #2
Captainfab
60-66 Nut
Re: brake lockout?
That part in the first pic is your proportion valve. That is needed when you have disc brakes on the front and drums on the rear, or 4 wheel disc brakes.
Old 11-28-2010, 01:42 AM   #3
kev63rod
kev63rod's Avatar
Re: brake lockout?
ok well i thought at first thats what it was but it has a wire comming off it, what is that for?
Old 11-28-2010, 01:46 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
Re: brake lockout?
Should be for a warning light on the dash, if there`s a low pressure in the system..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-28-2010, 01:59 AM   #5
Captainfab
60-66 Nut
Re: brake lockout?
I agree. But since this isn't original to the truck, that wire may go nowhere.
Old 11-28-2010, 02:08 AM   #6
Rich 5150 69
Re: brake lockout?
That could be very true....
Old 11-28-2010, 02:35 PM   #7
kev63rod
kev63rod's Avatar
Re: brake lockout?
thanks guys for the answers. the wire goes to nothing thats why i wondered. i only gave $300 for the truck so i think i did ok. hopefully the motors ok.
