What manual tranny are you runnig
Im trying to get a parts list together for my 65, and would like to run a 6spd trans, i wanted to what you have and any probloms you had with it
Intentionally Left Blank
Re: What manual tranny are you runnig
I used a TKO 5 speed. I don't remember any major problems, but it has been about 10 years or so since I put it in. I had to have my drive cut down. (Actually I just had a new one made instead). And the shifter is far back, but I have bucket seats, so that didn't matter. The only thing I'd look at is where the RPM's are going to be when you're on the highway. A 6speed is going to be pretty low in rpm range and these trucks aren't very aerodynamic. You don't want to be so low in RPM's that you can't cruise in 6th gear and still use the throttle to pass someone without having to downshift. And you don't want to be lugging the engine just to run in 6th.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
![]() Join Date: Nov 2007
I am running a T56 6 spd. 2:1 overdrive in 6th makes for fine cruising. 70 mph at 1700 RPM (3.73 rear gear). As Dark1 mentions you do need some horses.
Difficulties: New crossmember needed, Need to modify e-brake gimikus, shifter is way back so I had to move it forward to use the bench seat. That is a big job - see this link. http://67-72chevytrucks.com/vboard/s...d.php?t=300892 I used the hydraulic clutch that came with the tranny, so that was another job, see link on that. http://67-72chevytrucks.com/vboard/s...d.php?t=300087 The PIC is before I got it painted and back on the road. Was it all worth it? Oh yea. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 Last edited by TR65; 12-03-2010 at 11:39 PM. Reason: links not right |
![]() Join Date: Oct 2006
urrrg cant open links !!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
Whoops. Sorry, I messed up. Should work now.
TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
why a six speed. the 5th to 6th split is not very far, I looked about buy the TKO 6 speed but after talking with a few that had it went with the TKO 600 5 speed. with a .64 over in 5th... The 6 speeds are good for road racing and things like that .. most said that they would just skip shift it as the 6 speed thing got old and was more shifting than needed... dont get me wrong 6 sounds good to me only passing on what I gathered.. My 5 speed is more than enough and many times I skip shift as well.. if I am being lazy
just read through your swap, I ran a 413 stroker in a sand rail and used a Mefi computer and it is a 3 wire deal , your swap looks great I can see the time you put into it very nicely done!!!
The champion rad you bought what was the cost my stocker is still holding up well but have thought about upgrading as it is old .... no leaks yet but since I have it out might swap it.. does that company make one for a 62?? |
Thanks GMR,
He has 2 row and 3 row for a 62 ($150 , $200). My 3 row really cools good. The fans never come on unless I let it sit and idle for a while in SC summer heat. http://stores.ebay.com/Christian-Rad...4.l1581&_pgn=2 TR
The reason for a 6spd is i travel about 40mi a day to work, so i thought a 6spd would get better mpg. As of right now i am getting parts together. I have a 72 350 4bolt that i would like to get 400hp---3.73 12 bolt rear end complete---now just looking for a trans. And if i can come up with some cash i found a guy selling a magna supercharger for $500
i would love to have a T56 but I am swapping over from a saginaw 3 speed to a Saginaw 3 speed w/ OD. Also will keep it on the tree.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet |
#11 | |
I live in the mountains so we run the gears alot and this has been a dream to drive... You could get there with a t-5 as well...... If you go the 6 spped route post it up... nothing like being different.... I am installing a 7 speed trans in my harley.. 6 speed is stock so one more to go >> ![]() |
I am running a T-5 and am very satisfied with the results. It was a cheap easy install, but I would not recommend a T-5 if you have a lot of power, sticky tires, and like to thrash it.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
#13 |
![]() Join Date: Oct 2009
since you are planning on a 3.73 rear, I think you'll be good to go with a .64 o/d 5 speed (from the engine's perspective, especially since you're planning on about 400 hp). The 6-speed seems overkill, and the final ratio really isn't gonna get you much better mpg seeing as you'll be spending 20 of the 40 mile daily trip with the clutch in... (and you might start to see too low rpm at highway speeds unless you're spending much time over 75-80 mph)) I vote 5 speed! (at least that's what I'm saving my pennies for anyway). Good luck - and can't wait to see some build pics of the install....
#14 |
is the 6 speed going to be collecting dust?
66 suburban 51 Merc 2 door coupe 38 Chevy Business Coupe (gf's) 76 Airstream Sovereign |
#15 |
![]() THANKS FOR ALL THE INFO |
#16 |
Yeah to get good mpg with a carb'd V8, 1800rpms at 70 is the tallest I would go, as anything less is lugging it. Some guys with the 6 speed would actually get slightly better mileage in 5th gear.
Thats my next winter project for my 64, swap the 3 on the tree for a T5. That is, if I end up keeping the 6 banger in her...
1982 K10 SWB 1987 V20 - Sold - Doh! Last edited by TwoFiftyShifter; 12-09-2010 at 05:38 PM. |
#17 |
Well I vote for a 4 speed. I run a saginaw 4 speed out of a 77 vega, and my rear is 3.73. At 70 it runs at 2400 rpms but has tons of power and still fun to drive. The swap was very easy. The original 4 speed bell housing bolts right to the Saginaw. The bellhousing basically is the mount, so no need for a new crossmember. I have a hurst shifter, and a bench seat. It took a little bit of modifying to mount the shifter to the tranny, but very little. It clears the seat with no issues.
#18 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You must have a 3.08 rear gear with rpm's that low at 70 mph.
#19 |
TKO-600 5 speed is awesome.Shifter can be relocated(pricey,but can be done).It turns @2100 at about 70 mph with a 3.90 ratio and 27" tall tires.What little time I got to drive it before the teardown I had a blast!Pics show it with the mid shift relocation sitting beside a saginaw 4 speed,what a difference!Also,it wouldn't clear my low hump tranny cover.
#20 | |
Posted via Mobile Device |
#21 |
You would have about a 33" tall to get those rpms right?
1982 K10 SWB 1987 V20 - Sold - Doh! |
#22 |
I make it as being closer to 36.5"
Ray
#23 |
Wow, bunch of ball busters. Ok I'll get technical and revise my statement. I went home drove my truck to 70mph it reads about 2550. I looked at the paperwork for my rear. Its a 10.5" 14 bolt corp with 3.42 gears. Sorry for the miss leading. 4th gear on a saginaw 4 speed is 1.00. tires 265/75/r16 by my tape measure shows they stand just shy of 31". So by my calculations my speedo is about 2 mph slow. So it's still not to bad, and fun to drive. Not to mention that those transmission are a dime a dozen. Easy, fun, and affordable. You can get a rebuilt one for $500 or less. The only other tranny in this price range is the T-5. T-5 can barely handle a mild 350. If you dont have deep pockets consider the 4 speed.
#24 |
I did move mine up to the front location and at the time it was 500 or so extra now you can buy the trans with shifter in the forward location. THe mid location is too close for how I wanted it. But it can be done that way. By the way I do have all the parts for the mid and rear location if someone needs them for what ever reason.
#25 | |
60-66 Nut
I wasn't trying to bust any balls. I just assumed you had a C10 with a shorter tire like say a 26-27" tall tire. My fault for assuming...sorry
![]() So with that combo, do you have to slip the clutch much on take off? Quote:
