Old 12-07-2010, 08:14 PM   #1
skysoldier173rd
skysoldier173rd's Avatar
Question rally wheels
I am confused what (if any) rally wheels will fit my 60 gmc 6 lug. One vendor says there are over 600 different rally wheels made by GM alone. I don't know if i believe their claim, but I am confused by different stories i have gotten regarding this. I am aware that the centerbore of the trucks like my 60 are bigger than the newer wheels. My question is what years WOULD fit if any. I'm not sure what year the rallys started, but i think it was sometime in the early
80's but i'm really not sure. What WILL fit on these trucks besides the OEM given the larger center bore? Almost none of the newer aftermarket wheels will fit for the same reason from what i can tell. Also, if i were to get a micrometer measurement of the size centerbore hole needed to fit, what would it be?
skysoldier173rd is offline   Reply With Quote
Old 12-07-2010, 08:29 PM   #2
johan 1
Re: rally wheels
I bought a new set of really wheels from a local guy here in ontario . he bought it in the usa . I did try them first on me truck before i bought them from him and the fit fine , I have dish brakes on the front and they clear the brakes. I will check tomorrow for the part number and the company where he bought it from ,I will post a picture tomorrow from the rims.
johan 1 is offline   Reply With Quote
Old 12-07-2010, 10:44 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Re: rally wheels
I'm not sure exactly what Rally style you mean; there are a few plus some aftermarket. I just used a set of 73-87 pick-up 6-lug Rally wheels on my '66. They fit the rear axle hub exactly( 3.5''dia I think ). On the new disc front they are slightly larger than the hub. I think the hub must be 3.25''dia.
Here is a pic before I got my new tires and wheels mounted on the truck........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-08-2010, 01:56 AM   #4
Captainfab
60-66 Nut
Re: rally wheels
I think the 6 lug 4x4 Rally's started around 1970. But the '73-'87 ones are easy enough to find. Since they are a 4x4 application, they have the larger center hole for the front differential hubs. Which happen to be the same size as our trucks need.
Old 12-08-2010, 01:49 PM   #5
raycow
Re: rally wheels
The small center holes started in 88 and the offset changed at the same time. You should be good with any wheels up through 87.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-08-2010, 01:58 PM   #6
jchav62
1962 C-10
jchav62's Avatar
Re: rally wheels
Many companies sell Corvette/Camaro style rallys for 6 six applications.. We have a set on our '65...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 12-08-2010, 05:28 PM   #7
62 Longbed
62 Longbed's Avatar
Re: rally wheels
I have the Rallys on my 62 pickup .. These Rallys should fit your Truck without any problems ... Get a set of center caps and find some GMC center Decals and your on your way .. Good Luck !!
62 Longbed is offline   Reply With Quote
Old 12-08-2010, 05:30 PM   #8
62 Longbed
62 Longbed's Avatar
Re: rally wheels
As for the over 600 Rallys from GM ... Probably Yes .. If you count every GM car and Truck made from ?? thru Present ... But not in 6 Lug Wheels ..
Old 12-08-2010, 08:43 PM   #9
skysoldier173rd
Re: rally wheels
Thanks Guys, just what I wanted to hear.
