Old 12-09-2010, 10:54 AM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Wiper speed question
I have a one speed wiper and it runs faster than I want it too. Is there a way by using a rheostat to make the speed adjustable?
If you have done this, what did you use for a switch/rheostat?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-09-2010, 11:41 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Wiper speed question
This switch will give you two speeds. I tried one on my truck and it gave me slow, and dead slow. If your normal speed is faster, this might be just what you're looking for.
http://www.ronfrancis.com/prodinfo.asp?number=WS%2D1
Old 12-09-2010, 11:59 AM   #3
61_FL_Apache
Who Me?
I think you had showed me that one before. Im kinda looking for something like a dash light dimmer switch.
Steve
2001 Blazer 4D 2WD
Old 12-09-2010, 01:05 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Hopefully someone with a lot more electrical experience will chime in, but it seems like you could go to any electronics store and pick up a rheostat of sufficient capacity to handle the load of the wiper motor in continuous operation, and wire it into the wiper circuit. Not sure where you would find out the amperage draw of the wiper motor, or how this converts into watts. Perhaps someone at the supplier site could help. I see Newark for example has a “Live Support” button available.
Something like this:
http://www.newark.com/jsp/search/pro...FC-GB100000001
Old 12-09-2010, 01:26 PM   #5
Real_McCoy
Real_McCoy's Avatar
http://www.persh.org/Pickup/Wipers.htm
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 12-09-2010, 01:28 PM   #6
61_FL_Apache
Who Me?
Back from Newerk tech support chat.
The questions asked that I couldnt answer were Ohms and Watts needed. Im sure they have something that would work, but I didnt know how to answer those questions.
Steve
2001 Blazer 4D 2WD
Old 12-09-2010, 01:28 PM   #7
StevieC
man I remember when those wiper delays were the latest in high tech!
and pricey!
StevieC is offline   Reply With Quote
Old 12-09-2010, 01:29 PM   #8
61_FL_Apache
Who Me?
Originally Posted by Real_McCoy View Post
Good link!! That looks like something I can gut and use at the wiper switch.
Steve
2001 Blazer 4D 2WD
Old 12-09-2010, 01:31 PM   #9
61_FL_Apache
Who Me?
Here is it.
http://www.jcwhitney.com/wiper-delay...wx?filterid=j1
Steve
2001 Blazer 4D 2WD
Old 12-09-2010, 01:41 PM   #10
Putter
More Cowbell....
Putter's Avatar
But don't you want to slow the speed down....not delay the actions?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-09-2010, 01:46 PM   #11
61_FL_Apache
Who Me?
That is true.
I figured out the Wattage portion of this puzzle. Its Volts x Amps = Watts. The motor is probably 15-20 amps. That would put it in the 180-240 watt range. I dont know what ohm rating I need for resistance.
Steve
2001 Blazer 4D 2WD
Old 12-09-2010, 03:36 PM   #12
raycow
You need to measure the actual current draw with a multimeter in order to calculate the resistance needed. I am pretty sure its not going to be anywhere near 15-20 amps unless you heavily load the motor. You could try a heater motor control, but if my experience is any guide, it will NOT have enough resistance. Maybe a coil resistor might do the job.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-09-2010, 03:50 PM   #13
dracko
dracko's Avatar
Nice! Definitely need to order one of these up....then install a washer fluid setup.
dracko is offline   Reply With Quote
Old 12-09-2010, 05:34 PM   #14
61_FL_Apache
Who Me?
Ray
I would think the coil type is what im looking for. If you look at the headlight switch in our trucks, there is a ceramic area for the light dimmer. Its probably going to be like that.
Steve
2001 Blazer 4D 2WD
