Old 12-10-2010, 01:46 PM   #1
jimmydean
jimmydean's Avatar
Saddle tank option?
So my '66 has a smallish 2nd tank mounted on the drivers side with the fill in the wheel well. Anyone else have one and know what the size is?
When I bought the truck, it was switched to the side tank and the gauge showed near empty. There doesn't seem to be a gauge for the 2nd tank, so I haven't used it since I got it home. If it's big enough, I want to keep it as my primary so I can toss the cab tank.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 12-10-2010, 03:26 PM   #2
turbostar
Re: Saddle tank option?
Give the dimensions and it is easy to calculate the size.
turbostar is offline   Reply With Quote
Old 12-11-2010, 01:36 AM   #3
Captainfab
60-66 Nut
Some of these older trucks had aftermarket saddle tanks installed by po's. If it has square cornere and looks like it was welded together, then that's what you have. I've not seen many of those with sending units in them.
