Old 12-17-2010, 08:36 PM   #1
rdlackey
64 trim moulding
Is there a "trick" or a preferred tool that can be used in removing the aluminum trim mouldings on the sides of the truck body panel?
I know they attach onto clips, but don't want to be overly ambixious trying to remove the existing pieces, so as to not do damage to the paint.
rdlackey is offline   Reply With Quote
Old 12-17-2010, 08:51 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: 64 trim moulding
I used plastic wedges that I cut into small pieces and taped and just worked them in until the trim popped, you can use a few along the strip so as not to bend the trim.
LT1 Burb is offline   Reply With Quote
Old 12-18-2010, 08:34 AM   #3
duallyjams
duallyjams's Avatar
I thought there was a tool that would turn the clip to release the trim ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
