Old 01-19-2011, 08:35 PM   #1
jitteryguy
GoatLube Experss
jitteryguy's Avatar
tubular LCA's on a 1 ton
I try'd to search for my answer but keep get'n side track'd , I have a set of DMJ upper and lower controll arms that I bought from a fellow board member , he took em off a 1/2 ton suburban, if they'll work I wanna use em on my Dually.
thanks in advance
Chris
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-19-2011, 09:50 PM   #2
SCOTI
SCOTI's Avatar
Re: tubular LCA's on a 1 ton
Different size lower ball-joints. 1/2 ton lower ball-joints have a smaller OD than a 1-ton. The stud is smaller as well if I remember correctly.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-20-2011, 12:32 AM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
so............. perhaps I can replace the ball joints and use em ????
'85 1/2 ton CCSB
'92 S10 350/350
Old 01-20-2011, 12:36 AM   #4
SCOTI
SCOTI's Avatar
Lower BJ's won't interchange between 1/2 & 1-ton so it's doubtful. You would need to cut out the BJ opening on the a-arm & re-weld in the correct size ring for the 1-ton BJ.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
