Old 02-03-2011, 12:44 AM   #1
Toxic Redline
Toxic Redline's Avatar
HELP Replacing front window.
ok i have an 84 k20, it has the "chrome" insert around the windshield and it needs to be replaced, i've done the rear window like 4 times,, is the front windsheild harder to do??? like can i grab one at the "junk" yard and put it in easily or just pay the 150 to get a new one installed??
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 02-03-2011, 01:10 AM   #2
primrrd
primrrd's Avatar
Re: HELP Replacing front window.
front may require a little more work than the rear because of the curves, but it is basically about the same. You will need the dash pad out.
You might want to shop the price. I can get a 100.00 installed brand new windshield with the internal antenna in Houston. Almost not worth doing it myself....
primrrd is offline   Reply With Quote
Old 02-03-2011, 01:42 AM   #3
csb#356
It really depends on how cheap you can get it done. I personally got a perfect windshield at the junk yard for 20 bucks and it took me and my buddy a couple hours to put it in and that was because we didn't use big enough rope the first time and it snapped. When you put it in, put the seal on the windshield and then start at the bottom and work your way around with the rope trick. If me and my friend can do it with a box of pbr's, so can you.
csb#356 is offline   Reply With Quote
Old 02-06-2011, 01:14 AM   #4
Toxic Redline
i picked one up today from the junkyard.... hope it goes well
68 c20 dump bed
Old 02-06-2011, 01:51 AM   #5
DREAMER1
DREAMER1's Avatar
Whereabout in Houston?
DREAMER1 is offline   Reply With Quote
