Old 02-07-2011, 01:44 PM   #1
lsteiner72
Lower Questions
Hi All,
I was wondering if a c-notch to the rear frame is necessary for a 3.5 / 5 drop?
Also what suggestions do you have for a drop and tire size (pics if possible) the truck is a 70 LWB. I know all will sit a little different but just looking for more input.
lsteiner72 is offline   Reply With Quote
Old 02-07-2011, 03:57 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Lower Questions
lsteiner, welcome to the board.
No, a c-notch is not required for a 3.5/5 drop.
Here's some shots of my shortstep with a 3.5/5 drop.
Here it is with 15x8 wheels all around and 255/60/15 front 275/60/15 rear.
And here with 17x8 255/50/17 front 17x9.5 275/55/17 rear.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-07-2011, 04:47 PM   #3
ATrain707
Re: Lower Questions
here my brothers 71 lwb i dropped for him 3/5 n c-notch, 15in rims
ATrain707 is offline   Reply With Quote
Old 02-07-2011, 04:49 PM   #4
ATrain707
Re: Lower Questions
sorry pics didnt upload in last post
Old 02-07-2011, 07:39 PM   #5
WHYBYNU
WHYBYNU when old will do
WHYBYNU's Avatar
Re: Lower Questions
Here is mine 4/6 drop no c-notch.
Wheels are 20x8 front - 20x10 rear
Tires are 255/40/20 frt - 295/40/20 rear.
BTW Welcome to the best damn truck site on the web !
71 Cheyenne super
2 tone green and white
ZZ6 - Th350
4/6 drop
20x8.5 / 20x10 Billet Specialties
WHYBYNU is offline   Reply With Quote
Old 02-07-2011, 09:41 PM   #6
chevykevy
chevykevy's Avatar
Re: Lower Questions
I am thinking of doing the same drop.
My question is if the driveline on a shortbox(one piece) will need to be shortened so it will not move forward into the transmission?
chevykevy is offline   Reply With Quote
Old 02-07-2011, 10:01 PM   #7
lsteiner72
Re: Lower Questions
Thanks for the info and pics guys, please keep some more coming!!
Also thanks for the welcome to the site, I hope to get some pics of the dismantle up soon, there are some very good ones from the A&L S Customs and Restoration shop.
Old 02-07-2011, 10:39 PM   #8
Jeffs70
Jeffs70's Avatar
Re: Lower Questions
I have a 5/6 static drop with no c-notch
Jeffs70 is offline   Reply With Quote
Old 02-08-2011, 12:20 AM   #9
SCOTI
SCOTI's Avatar
Re: Lower Questions
I've done @ least 3 swb truck arm trucks @ 6" rear drop & did not change the 1pc shaft. It's still a good idea to take measurements & be 100% sure on your particular parts combination.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-08-2011, 09:50 AM   #10
68Stepbed
68Stepbed's Avatar
Re: Lower Questions
I didn't have to shorten my driveshaft.
Matt
Old 02-08-2011, 01:08 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Lower Questions
It is a good idea to C notch the chassis if you are going to drive the truck much. The is room to do it without, however your trucks rear end travel is severely limited. The original person whe lowered my panel 5" in the rear didn't C notch the frame and every time I hit a good bump in the road the rear end woul smak the bottom of the frame. Not good for the truck nor comfortable to ride in. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-08-2011, 01:16 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lower Questions
Hey Wes,... I'm not sure you can compare trucks with the Panels and 'Burbs.
I've done several trucks with 6" drop rear springs and no notch.
They were all fine.
However,... When I tried the same thing with my old '69 suburban,... I had the same results as you described with your panel.
It definitely needed a notch.
I wonder if the frame is different,... or if it's the extra weight of the roof/glass/etc.?
Keith
Convert to disc brakes.
Old 02-08-2011, 01:29 PM   #13
Classic Heartbeat
Re: Lower Questions
I am sure it is the extra weight. The chassis design is the same in that area. They use the same C notch kit. Mine would hit with what seemed to be the smallest of bumps (example: driving down the freeway and coming upon a bridge) I use to own a 68 short stepside, and it was dropped 6" in the rear and it would bump the frame coming into my parking area if I didn't slow down enough. A shock relocator kit helped with that, but it would still bump occasionaly. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-09-2011, 04:34 PM   #14
lsteiner72
Re: Lower Questions
Thanks guys, what do you think and about a 3.5 / 5 setup then?? really didn't want to notch...
Old 02-09-2011, 04:46 PM   #15
Classic Heartbeat
Re: Lower Questions
If 3-5 is what you want, then go for it. As stated in post above results may varry. I would even do the 6" rear drop if that was what I wanted to do. If you do not C notch you can always go back if your circumstances warrent that. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 02-09-2011, 05:13 PM   #16
68Stepbed
68Stepbed's Avatar
Re: Lower Questions
Do it!!!!!
Matt
Old 02-09-2011, 06:58 PM   #17
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Lower Questions
I did the 3.5/5 with no notch, and no problems after 600 miles. 255/45-18 and 295/45-18's on 8 and 9.5 Coys C5's
Zoomin is offline   Reply With Quote
Old 02-09-2011, 07:55 PM   #18
wwotr
wwotr's Avatar
Re: Lower Questions
5.5" Front Drop and 6" in back and no c-notch.
Done with Lowering Spindles (in front)with a Shock/Spring kit along with 2" Drop Blocks in the Real.
No shock relocators.
Drives fine.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
