02-08-2011, 11:28 PM | #1 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Dash Pad Removal???
Are the dash pads riveted on the ends? Can someone please explain the R+R on a dash pad removal procedure? Thanks for the reply's...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
02-08-2011, 11:34 PM | #2 |
Re: Dash Pad Removal???
they are just screwed/bolted there are the 4 screws and then there is 5 or 6 bolts (they are the same bolts as the emblems for the fenders) the old ones are a pita to pull off for some reason! the new ones go on good and come off good
02-08-2011, 11:42 PM | #3 |
its all about the +6 inches
count on pulling the inst panel, radio, center A/C vent (if equipped) and the glove box liner. It can probably be done without removing all this, but you won't want to do it that way.
02-08-2011, 11:42 PM | #4 |
Right on, and thanks for the quick reply Rick! Im headed back out to the shop! I got the four screws out no problem, when I pulled on the old pad that seemed to be stuck or glued, the end broke off and exposed what appeared to be a rivet! I think Ill grind the end screw heads to free the steel straps through the old pad. Sound feasible? I have a new pad to reinstall. Thanks Longhorn for the reply!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 02-08-2011 at 11:44 PM. |
02-08-2011, 11:45 PM | #5 |
it does just be car ful with your dash! good luck and take pics to! i took mine out but still need to buy a red one and install ....your welcome buddy!
02-09-2011, 12:04 AM | #6 |
I would suggest following Longhorn Mans advice, sounds like he's actually done it once or ten times.
02-09-2011, 12:10 AM | #7 |
Chevy Truck Addict
As Longhorn suggested, you'll be a lot further ahead taking some items out of your way. It can be done but is not easy. The bolts stick through to the backside of the dash... Some are relatively easy to get to, some aren't. Stick your arm up behind the dash and you should be able to feel them... There is 1 at either end and then 4 or 5 in between. The ones behind the cluster and above the radio can be a PITA.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
02-09-2011, 12:12 AM | #8 |
yes long horns man is nice ......man i even sound like i dont know what i am doing??......
02-09-2011, 12:13 AM | #9 | |
02-09-2011, 12:33 AM | #10 |
VA72C10
Just to add....some of the trucks I had where people switched them out they used adhesive and no bolts at all due to the hard nature of the installation...so I'd check to see if it will come up easily...
....and depending on how much you're doing on the interior put it back on before you put your glovebox, radio, and cluster in...
Looking for a 67-72 swb or blazer project in or around VA. |
02-09-2011, 12:46 AM | #11 | |
This is sort of a temporary solution if you are not wanting to take every thing apart right now. The four screws on the outside of the new pad will hold it in place til you get ready to do the 7 bolts or the ones you cant reach now.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 02-09-2011 at 12:53 AM. |
02-09-2011, 01:36 AM | #12 |
Hey Thanks for the reply's you guy's! That "suck factor" just shot out of sight! I closed the shop and will dismantle the whole dash tomorrow. This did resolve a decision to paint the dash or not. Ill go ahead and look into sliding that steering column forward a bit while everything's apart. Im going to have a screw driver or a wrench on every bolt and screw on this old girl...whether I want to or not! Ill post pics tomorrow...Thanks again
02-09-2011, 03:31 AM | #13 |
I am a Referee of life.
A 1/4 socket set and extensions will help a lot..
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
02-09-2011, 05:58 AM | #14 |
plus using a palm rachet makes it very easy to do
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 02-09-2011 at 07:05 AM. |
02-09-2011, 06:02 PM | #15 |
I guessed I shoulda said it more like this...
if you try to do it without removing alll that stuff, it'll make you want to punch a nun in the face you'll be so ticked off. I gotta say, I DO like the sawzall idea. |
02-09-2011, 06:54 PM | #16 |
low n' slo
i used my cutoff wheel..just be careful!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
02-09-2011, 06:58 PM | #17 |
Moderator
a gear wrench works great too
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-09-2011, 08:33 PM | #18 |
Wow I didn't know that there was so many was to screw in a light bulb!!
"The Can't Family Lives Across The Street" |
