Old 02-26-2011, 01:49 PM   #1
Mack81
70's era hotrodding...history lesson please
After many months of constant thinking about what direction I wanna go with this truck I've decided on doing an early 70's-era street freak. I wanna stay period correct as best I can even though I'm 30 and this style was before my time. My good friend has been hotrodding for almost 40 years and he remembers this era of street cars being jacked way up in the rear with shackles and air shocks, slotted mags or crager ss', tunnel ram with a bird catcher, and glass-pack header mufflers like "purple hornies." I have a slightly different idea, but it's best to hear it from the experts.
I have little to no regard for street manners with this thing because it will be at the track 90% of the time running street trophy brackets. I just really want to do it with the 70's flavor and period correct parts. I was raised in the pro-street era so for you guys running the streets in the early-mid 70's, how did you do it?
'68 C10 SWB
"Purple Nurple"
Mack81 is offline   Reply With Quote
Old 02-26-2011, 01:53 PM   #2
CG
BlahBlahBlah
Re: 70's era hotrodding...history lesson please
Get a hold of car magazines from that era for the best info. I seldom saw tunnel rams with bird catchers. Most of em ran velocity stacks. You should be able to attain the look you want using todays technology. Avoid the long shackles and mickey mouse stuff we did back in the day. Sounds like a fun build, will be looking forward to progress pics.
Old 02-26-2011, 02:36 PM   #3
yeah,look at some old magazines. Guys used long shackles a lot,but they did a lot of cheesy things. It wasn't as common for someone to go as far as we go these days. But,even back then doing it right would be custom spring work. Air shocks were definitely used and if you run leaf springs,Lakewood "slapper" bars were common. But again,the classy rides would run ladder bars. Big/little tire/wheels were big and raked stance,too. But,the better rides ran the front up,too. Guys would go as far as running smaller diameter wheels up front for a real nose dive look. To me running big block springs gave more of a track look. It was at the end of the straight axle era and tires were still not what they are today. So the thing was to get more weight to shift over the rear for traction. Snorkle scoops were big,but for a real street freak look you wanted to see the motor up through the hood...like a blower or dual carb tunnel ram. The street freaks ran side pipes mostly. Zoomies were big. But a street/strip ride just ran the pipes in front of the rear tires or Purple Hornies. Cragar S/S and Keystone Klassics were common,as well as slots,were common choices in the early ;70s. Turbine wheels came on a bit later in the '70s. Roll & pleat interior was still common if any interior work went on.
Old 02-26-2011, 02:42 PM   #4
bsteenburg
L60 or N15 tires on the back, air shocks and shackles, flared rear fenders, either dumped low in the front or jacked way high, 11-1 pistons, Holley 780 on aluminum high rise, chrome valve covers, Hooker headers, Cherry bombs or Purple Hornies dumped at the axle or out the side, close ration 4 speed with Hurst comp. plus or Mr Gasket in line shifter with Tee handle, Cragers or Ansen slots for wheels, huge Sun tach, big thumper mechanical cam, cool can, full pressure Hays clutch assy. that you could barely push in, hood scope of some sorts, velocity stack with filter. The sound system was 6x9 Jensens in the rear deck, 4" rounds in the front hanging from the dash, a Kracko from Radio Shack.
If you had money it was 2 4"s on a tunnel ram or a 6-71 blower.
Bryce
bsteenburg is offline   Reply With Quote
Old 02-26-2011, 02:45 PM   #5
trevrolet65
Yeah, remember Lakes?
trevrolet65 is offline   Reply With Quote
Old 02-26-2011, 02:49 PM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
Over here I remember Dralon (velvet) buttoned interiors, porthole windows in vans, murals, jacked up rear ends with foot long shackles, red painted rear axles with a red light shining on them, chrome side pipes (usually non functional) furry dice hanging from the rear view mirror and wolfrace slot mags, usually on a slightly rusty MK2 cortina.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-26-2011, 02:54 PM   #7
bsteenburg
Forgot dual point distributor and slapper bars.
Bryce
Old 02-26-2011, 02:59 PM   #8
bsteenburg
Houndstooth or tuck and roll interiors. Bucket seats open between them. Always had a small pillow in the back seat. Hid the bong between seats and tunnel. LOL
Bryce
Old 02-26-2011, 03:34 PM   #9
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Old Style Americans, white letters out on 15", bigs in back, littles in front. Mines lower than I remember them in the 70's. I'd like to have some sidepipes to hold up and see what the look like, I don't know if I would run them tho
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 02-26-2011, 03:56 PM   #10
ItsRandy
ItsRandy's Avatar
Bryce
Hid the bong? That's where I went wrong!
ItsRandy is offline   Reply With Quote
Old 02-26-2011, 04:22 PM   #11
bsteenburg
Yep!! and its not like I was the only one either!!! Sex, drugs and rock'n roll surrounded with hotrods was very popular. Booze of all sorts was everywhere at anytime. Just the way it was. Same as it is now with kids, just handled different back then.
Bryce
Old 02-26-2011, 04:47 PM   #12
Rochlow
I'm taking the same approach with my jimmy. Just with a modern air suspension. When aired out it still has that 70s rake with cragar SS wheels. I've been tossing around the idea of side pipes.. Just not sure yet.
Rochlow is offline   Reply With Quote
Old 02-26-2011, 08:54 PM   #13
Mack81
I already have alot of parts to get this going but some of them are questionable era-wise.
How about a yes or no on the following parts:
-noisy gear drive
-blue window tint
-t handle auto ratchet shifter
-fenderwell dump headers painted white (I'm going nose high look)
-6/8" car rallys (maybe painted copper)
-30" tall Blackwall pie crust cheater slicks
-aluminum fuel cell
-big block front springs with urethane buckets and Balljoint spacers
-2" lowering blocks in the rear
'68 C10 SWB
"Purple Nurple"
Old 02-26-2011, 09:06 PM   #14
trevrolet65
Those were the old side pipes
Old 02-26-2011, 09:43 PM   #15
bsteenburg
Yes on all that, sounds about right.
Bryce
Old 02-26-2011, 09:57 PM   #16
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
It's funny. Most of the crazy crap people would do back in the day wouldn't even let you pass inspection onto the track today. Like jacking the front end way up in the air with a spindly straight axel to improve weight transfer. True drag cars would never raked the front like the kids would do to their street cars. The front end was always high to the sky. Drag racers where all about speed and not frills. So you would never see craiger wheels or anything heavy or fancy like that. Just basic steel wheels. Exhaust dumps off of fender headers. Beer can radiator overflows. Big holes cut into the frame to lighten the car. Huge holes cut threw the fire wall so you could move the engine back into the cab to improve weight transfer. Their is a reason you don't see most of their modifications around anymore. Though, some of them look cool. Don't forget the metallic flake paint. Lots of racers would just paint their cars Hot rod black (Black Primer) The Rockabilly look with primer black car with red wheels was from the 50's and 60's and died out in the 70's But if you want to pimp it out 70's style. you got to lay down some metallic flake paint. Not the metallic flake you see today. It's old school huge flake metallic paint. Flake so big it wont shoot through a paint gun. Hand painted pin striping Von Dutch style is a must as well. Diamond tuck interior was way popular too. And if you are looking to have a name or logo on the side. It's got to be done with gold Leaf. It's the gold lettering you might still see on some fire trucks today.
Have fun with it.
Torrey72 is offline   Reply With Quote
Old 02-26-2011, 10:02 PM   #17
Mack81
Yeah I'm putting "Purple Nurple" on the bed sides in gold leaf. Since it's purple with blue flames right now.
'68 C10 SWB
"Purple Nurple"
Old 02-26-2011, 11:08 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Gear drives was a little later.
Late Sixties/early Seventies was when I was in the USAF and in Arizona. Ansen Sprint wheels were common. Running Purple Hornies behind your headers was not uncommon, but Cherry Bombs were also good. Air shocks were good. Velour button-tuft interiors with shag carpet and lace panel paint, or vinyl coverings on the roof top were also seen. Firestone Wide Ovals and Goodyear Polyglas GT tires were the hot ticket. I don't recall a lot of window tinting. It seemed to come on later in the Seventies...lots of heat by the cops because they couldn't see the driver. Now, the cops have dark tint. We also got a lot of flap about loud pipes, not like today. Kragar Kustomags, American 200S (Daisy) mags were popular. There were a lot of "mags" back then that I haven't seen for at least 35 years. Chrome wheels were always popular, mostly just un-capped. But, Cal Custom had a neat cap called the Black Jack. It looked a lot like the '60 Ford hubcap (not the full wheel cover). Scavenger pipes, with bazooka tips were common. Side pipes were not really common. 'Vettes had 'em, but most side pipes were out of style, meaning lakes pipes. Shorty dumps which exited behind the front tires usually had a two-bolt cap that could be swung out of the way, or they had a screw cap that could be undone and then you had an open pipe. Cars that were jacked up, were jacked up in the front. There was a 90/10 shock that was intended to help weight transfer to the rear. The rear wasn't jacked up, and it wasn't dragging, either. Shackles didn't come to be common until '72, or so. The hood scoops that I remember were the Ramcharger style, and the bubble, like Ford used on the late Sixties Fairlanes and Mustangs. Oh, Cal Custom had an aluminum one that was also used by Yenko. I have one of those in my "stuff".
Neat memories....
Member Nr. 2770
Old 02-27-2011, 12:06 AM   #19
bajaracing
bajaracing's Avatar
would look good 2me..
bajaracing is offline   Reply With Quote
Old 02-27-2011, 12:17 AM   #20
69 Okie Truck
69 Okie Truck's Avatar
Ladder bars and 50's pokin waaaay out the back.
The REAL bad boys ran open headers...law be danged....
69 Okie Truck is offline   Reply With Quote
Old 02-27-2011, 12:49 AM   #21
70cst
70cst's Avatar
Good reading ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-27-2011, 01:16 AM   #22
69 Okie Truck
If you dont go ladder bars you go traction bars with Moroso, Hooker, Holly and Crane stickers all over the windows.
Of course if you're trickin' out a Chevy truck you'll need the impossible to find ABS injection molded window louver for your back glass.
The shaker hood scoop was in vogue in those days too along with hood pins and hood tach, whether you needed 'em or not.
Of course it HAS to be four on the floor with a tricked out speed shifter.
Shag carpeting IS optional, 8 track player is NOT. Don't forget the ultra cool Jensen COAX speakers and the Tancredi power distorter...er, booster... to get all the foxy ladies attention.
The only thing left is the trip up to the corner Super Fuels for some premium fuel and a beer cooler in the back....'cause we could drink and drive back then.
Old 02-27-2011, 02:45 AM   #23
N2TRUX
Happy to be here
N2TRUX's Avatar
My buddies brother had a 62 Nova that was probably the epitome of late 70's hot rods. It was dark green metal flake, running N50's on 15x12 aluminum slots sticking out the rear. The back was lifted with High Jacker air shocks and ladder bars,the front was running a straight axle.
It had a 427 with a HUGE cam, tunnel ram with two fours and velocity stacks. They were gold anodized, and he had matching Moroso valve covers. Of course it had fenderwell headers and cherry bombs with turnouts. To complete the look, it had no front bumper and a tilt front end.
Man, it was like totally groovy...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-27-2011, 03:01 AM   #24
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Mack, great thread though it's making me feel kinda old
I guess I never grew past the 'make believe racer' styling that
street rods had in the 70's...still a fan of purple hornies and
a raked stance! (yes, I was a product of the era)
Carry on gents...subscribed!
ETsC10 is offline   Reply With Quote
Old 02-27-2011, 05:05 AM   #25
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Good stuff! My dad got into hot rodding in the late 70's and he's told me about some of the stuff he saw/built back in the day. It would have been cool to see it but it was before my time.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
