Old 03-18-2011, 03:44 PM   #1
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
Brake Drum specs
Hey guys,
I'm rebuilding my Dana 44 differential & at the same time putting in new brake shoes. I took the drums to O'Reilly's to get them turned, but they said they can't find any info on how thin they can be, so they won't turn them. Do any of you know how thin you can go or know where I could find this info?
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 03-18-2011, 04:39 PM   #2
blackedoutharley
Re: Brake Drum specs
With 11" brakes (11" X 2") the max diameter should be 11.060" if memory serves me correctly.
Edit: Just checked mine; they are stamped "Max dia. 11.090" " Your drums should be stamped with the max spec.
New drums aren't that expensive by the way.
blackedoutharley is offline   Reply With Quote
Old 03-19-2011, 01:00 AM   #3
Captainfab
60-66 Nut
New drums for the Dana 44 are hard to find, but it seems like someone here found a part number for them and where to get them. I just don't remember who it was. You might try a search here if you find you need new drums.
Old 03-19-2011, 10:32 PM   #4
slorio
slorio's Avatar
Captainfab:
I believe that was me. See this discussion:
http://67-72chevytrucks.com/vboard/s...d.php?t=412665
Regards,
Steve
New Orleans
slorio is offline   Reply With Quote
Old 03-19-2011, 10:36 PM   #5
slorio
slorio's Avatar
Here's two of the Raybestos 2067's that I mention in the previous discussion on Ebay for $43 each which should be good price for them.
http://cgi.ebay.com/ebaymotors/RAYBE...Q5fAccessories
I hope this is helpful.
Regards,
Steve
New Orleans
Old 03-21-2011, 06:45 PM   #6
littlee_domn8r
I didn't even think of looking on the drum itself, but after closer review, mine are stamped & they say discard diameter 11.06. Unfortunately, O'Reilly's says mine will be out of spec if they turn them, so I bought new ones from them & they are not the same drum. they dont have an offset hub like the stock ones do, so I'm guessing they won't work. LMC lists hubs for 45.00, but I will check out the ones mentioned by Slorio since he's already been through this.
I really appreciate the help on this, thanks guys!
Old 03-21-2011, 06:48 PM   #7
blackedoutharley
Did they even measure them prior to deciding that they won't be any good?
Take them to a brake shop and have them measured by somebody that knows what they are doing.
This is what I mean... they weren't able to look on the drum for the spec? They're supposed to be the pros but they missed this?
Old 03-21-2011, 06:59 PM   #8
littlee_domn8r
Yes they did, said they measure 11.01 & 11.012. I believe I will find an actual brake shop because I had to argue with the "manager" about which number was the discard one (11.00 or 11.06) the first time. Never hurts to get a second opinion anyway & if it saves me 80 bucks, then it's worth it.
Old 03-21-2011, 07:16 PM   #9
blackedoutharley
Absolutely!
At 11.010 & .012' that is plenty of meat to turn them provided they aren't gouged or anything. if they are smooth you should be able to turn them taking no more than .020" off. That would put them at near discard and they would need to be replaced at the next brake job but at least you will have time to prepare for that expense.
