Old 03-21-2011, 12:39 PM   #1
hotrodharley
Underbed gas tank
i know this has been discussed to death but here we go..i want a spefic answer and pics;;i have a 64 chevy truck[long bed]fleetside;;need to move tank to rear under bed..truck already painted and new wood already installed and bed mounted..i only want to know if there is any gas tanks that i can mount under bed that doesn't hang down very low[trk has drop kit]and i can come out behind lincence plate[rool pan]..do not want fill inside bed splashing gas on my new nice wood and paint job has flake and pearl in it so not able to match so don't want fill on bed side..ONLY BEHIND PLATE[if it can be done...don't care for how many gallons it holds[don]t need to drive any long ways to need big fuel supply]..low budget so no custom built or expensive alumium tanks please..need pics please
hotrodharley is offline   Reply With Quote
Old 03-21-2011, 12:59 PM   #2
dallas71
dallas71's Avatar
Re: Underbed gas tank
not sure if this will help....but check out this link
http://67-72chevytrucks.com/vboard/s...s+tank+mustang
dallas71 is offline   Reply With Quote
Old 03-21-2011, 01:01 PM   #3
65Gregg
65Gregg's Avatar
There have been several posts where early Mustang/Falcon/Cougar tanks have been used. IIRC the tank flange is the same as the frame rail or very close which allows the tank to sit andmount on top of the rails. There are also some posts that use Camaro tanks. These were all rear fill.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 03-21-2011, 02:00 PM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Underbed gas tank
63-66 Rear Mount Gas Tank Set - Steel/Rear Mount Underbed - Aluminum
http://www.brotherstrucks.com/products.asp?dept=1018
Chevy Truck Gas Tank, Aluminum, Bed Fill, 1963-1972 Part # 129016
http://www.ecklerstrucks.com/fuel-systems.html?limit=96
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 03-21-2011, 02:10 PM   #5
hotrodharley
checked these out already..won't work..has side fill and hangs way down past roll pan;;need to keep above roll pan and rear fill so can come out behind licence pl;ate;;;side fill as these kits i'd need to cut side of bed for fill and as i said..have new paint job and don't want to miss up paint job
Old 03-21-2011, 02:28 PM   #6
TopFuel1966
TopFuel1966's Avatar
You can use a tank that fills behind the license plate but you're gonna have gas splashing on you roll pan and your shoes.
TopFuel1966 is offline   Reply With Quote
Old 03-21-2011, 02:34 PM   #7
hotrodharley
that i can deal with more then having all over the walnut wood inside bed..just fill up slow and be adware of splash..just need a tank that will work this way
Old 03-21-2011, 02:39 PM   #8
1Bad62Pro/Street
Well, these links may or maynot help ya Bud.
http://www.boydwelding.com/tank-gallery
http://www.jegs.com/webapp/wcs/store...rm=Fuel+Cells+
http://www.summitracing.com/search/P...l&kr=fuel+cell
http://www.classicperform.com/6092chevtrk.htm#50
http://www.classicperform.com/tech_a...-It/Gas-It.htm
Old 03-21-2011, 02:40 PM   #9
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I saw somewhere here where someone installed an A or G body tank, I'll look.....
is yours a stepper?
http://67-72chevytrucks.com/vboard/s...d.php?t=390279
69 Camaro tank install, fill behind license plate.
http://67-72chevytrucks.com/vboard/s...d.php?t=448431
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-21-2011, 05:12 PM   #10
lakeroadster
I have not seen any tank threads that would meet your specifications.
Might I suggest you post a picture of your truck? Kind of depends what style roll pan you have, if your truck is a fleetside or a stepside and where the license plate mounts in that roll pan.
I was really concerned about the tank hanging low and used an unconventional tank to make sure it didn't. I also am running a roll pan with a license plate in it.
You can see the steel gray tank in this photo peaking out beneath the roll pan. If I was to install a filler neck behind the license plate there would be nearly no slope in the filler neck. The tank would only hold a about 4 inches of fuel which would equal at the most 4 gallons.
lakeroadster is offline   Reply With Quote
Old 03-21-2011, 05:20 PM   #11
hotrodharley
is yours a stepper?
this is what i'm talking about;;just might work..only differance is i have roll pan instead of bumper but looks as bumper is same location as the roll pan;;i have fleetside..thanks
Old 03-21-2011, 06:42 PM   #12
ljackson
ljackson's Avatar
Take a look in http://67-72chevytrucks.com/vboard/s...d.php?t=428182. There is a search link there. I built my tank. A drawing is in post #4. I have the fill going in the top of the tank. Maybe you could put it in the side.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate.
Maintenance, repairs and upgrades on his dime now.
http://zacks64longfleet.shutterfly.com/
Higher res. photos in my gallery.
ljackson is offline   Reply With Quote
Old 03-21-2011, 07:13 PM   #13
k1rodeoboater
click on the link in my sig...page 2 I believe has pics of the camaro tank on my truck
or just click here...
http://67-72chevytrucks.com/vboard/s...d.php?t=448386
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
