03-24-2011, 09:32 PM | #1 |
Flarestat model 105
I have a Flarestat Model 105 Y28. What was it used on? I have googled it and can't find anything.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! Last edited by 67_ShortFleet; 03-24-2011 at 09:38 PM. |
03-25-2011, 12:22 AM | #2 |
Re: Flarestat model 105
4 way flashers. I have a couple of them
ron |
03-25-2011, 09:26 AM | #3 |
Matt,
That gets mounted either through your dash or under it (depending on what you like) you have an original and they are on the rare side a bit because of teh bowtie emblem. Use it if you can. The GMC models are more rare because of the GMC emblem on the knob. Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
03-25-2011, 01:01 PM | #4 |
Looking at the connector, I'd say it fits 1959-1962. The 63-66 flashers have curved connectors.
03-25-2011, 03:03 PM | #5 |
Check The Champ, Demonstrator
Can't always trust the book. Picture is from the 1963 Chevrolet Custom Accessories Book. There was a jumper setup that after you unplug the original harness off the steering columb, you simply plug in the adapter harness. Mounts under the dash by your ignition switch.
Picture from 1964 GMC Accessories booklet. You can see it mounted under the key switch.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-25-2011 at 03:18 PM. |
03-25-2011, 06:06 PM | #6 |
Hollister, CA.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
03-25-2011, 08:14 PM | #7 |
03-25-2011, 08:27 PM | #8 |
03-25-2011, 08:32 PM | #9 |
so, if it doesn't have the little bowties on it, it's not original??
(BUMMER!! and here I though I had something kinda original!) |
03-25-2011, 08:44 PM | #10 |
but they were made for GM by way of the connectors
ron |
03-25-2011, 09:33 PM | #11 |
I've sen three in a junk yard one in a 59 and the other two were on 60 and all three had flare stat on the red pull knob.The 59 was mounted in the dash and both 60 were under the dash.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
05-02-2011, 10:42 PM | #12 |
do you or someone on the forum know where to fine 4 wat flasher Flarestat Model 105 Y28. to buy or parts . i saw it on here befor but can't kind the web site.
05-02-2011, 10:51 PM | #13 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=455298
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
05-02-2011, 10:57 PM | #14 | |
these guys ate the ones that bought them out. http://www.truck-lite.com/CSA/ ron |
05-02-2011, 11:10 PM | #15 |
Jocko,
That looks like a later model one with the flasher integrated onto the back. You can still buy them by the way from the original manufacturer, or at least using the original tooling. old chevy, So, you could buy a new mechanism and use an old knob on it if you wanted. I bought mine from Fleet Pride (heavy truck parts chain). Here is the thread with more than you ever wanted to know. http://67-72chevytrucks.com/vboard/s...d.php?t=323990 TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
