Old 03-27-2011, 01:33 PM   #1
FL71C10
Bad Power steering pump?
I just put the motor in my truck and got it running in the last two weeks. The truck sat outside for a while before I got it, and there was no ps pump or lines on the box. I am sure water giot into it, and might have ruined it. My motor had ps pump on it already. I hooked it us and the ps lines got hot really fast. I pulled the lines off and I'd like to test the pump to see if it is working. Can I just spin the pulley by hand to make it pump fluid?
Here is what the fluid looked like when I got some out. I filled the pump with fresh fluid before starting it, so I don't think it was that dirty. Looks nasty!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 03-27-2011, 02:25 PM   #2
Boog
laying low
Boog's Avatar
Re: Bad Power steering pump?
Yes it does. I'd pump that fluid into a catch pan then fill it up again and continue to flush until clear and it should work just fine.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-27-2011, 09:55 PM   #3
rico7769
Hybrid67
rico7769's Avatar
agree w boog. Good news is, new reman pumps are cheap but bad news is the rest of the parts they supply fluid to are labor costly. Should be able to flush though and get it running ok.
Keep em' Running!
All show.....no go
rico7769 is offline   Reply With Quote
Old 03-27-2011, 11:54 PM   #4
FL71C10
Should it pump fluid just by spinning the pulley by hand? I dropped the hoses below the level of the pump and the fluid runs through clear, but I doesn't spurt or pump any fluid just hand spinning the pulley. I ordered a steering box, but I want to make sure the pump works.
Old 03-28-2011, 09:14 AM   #5
jpert
If the hoses got hot the steering gear valving is probable stuck and the pump is running at high pressure or by-passing causing the heat.
jpert is offline   Reply With Quote
