Old 04-08-2011, 10:55 AM   #1
67chevemall
67chevemall's Avatar
Question Front disc conversion
Hey I was wondering what is an affordable way to get
3" drop spindles and front disc brakes on the 67 chevy.
Will I need a brake booster and portortioning valve too?
if so will the 73-87 chevy parts bolt on the 67?
Once I get going I'll use this as a build thread.
I can't put my front bags in until I get the drop spindles cause it just
wont sit low enough..even with the bags empty. bummer..was worth a try.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-08-2011, 03:38 PM   #2
67chevemall
Re: Front disc conversion
LMC is $299 for the spindles
early classic is $249
http://www.classicperform.com/Store/...ruck/CP4S1.htm
And Classic P is $209 but it says for C-20.... I'll have to call em.
good chart
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=131
Looks like 2.5 drop spindle and air bags will get you there....just have to play with the air psi for proper height...
I think after reading all the "kits" it is cheaper to just buy the
spindles and get all the 71+ brake parts local.....
smoke break....
Old 04-08-2011, 03:50 PM   #3
67chevemall
I guess the other issue is once converted and dropped one can't use the 15" rims anymore.....is nice to be able to use both the 15's and 18's.. always something else.
Is there anyway to use 15" steelies with a 2.5" drop spindle and disc brakes??
Old 04-08-2011, 03:55 PM   #4
71gmcburb
71gmcburb's Avatar
my 71 has discs and is on 15s
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 04-08-2011, 04:16 PM   #5
67chevemall
With 2.5" drop spindles?
Old 04-08-2011, 04:46 PM   #6
71gmcburb
71gmcburb's Avatar
as soon as my drop kit gets here it will have the 1.5" drop spindles and 2.5" drop springs. I am not near my burb right now but I don't think the spindle rides inside of the rim on a set of stock rims
easy way for you to tell is with your 15" rims on to measure from the bottom of the factory spindle to the rim. subtract the 2.5" and you will have your clearance
