06-09-2011, 02:32 PM | #1 |
Registered Cruiser
Replacing Wheel Stud for 12 Bolt
Hey guys, need some help here. I need to replace one wheel stud on each axle. They were missing when I bought the truck. I'm assuming I need to pull the axle's out and have new studs pressed in? How do I go about pulling the axle's? Should I replace seals or anything else while i'm there?
Not sure if it has posi or not, how would I know when looking in the housing?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
06-09-2011, 02:38 PM | #2 |
#16876
Re: Replacing Wheel Stud for 12 Bolt
I have always just drawn them in with a lug nut.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
06-09-2011, 02:55 PM | #3 |
06-09-2011, 04:13 PM | #4 |
Registered Cruiser
Sounds easy enough, feel dumb for making it difficult lol thanks!
06-09-2011, 06:11 PM | #5 |
06-09-2011, 06:18 PM | #6 |
Registered Cruiser
I've racked up a few now lol, thanks again, much appreciated!
06-09-2011, 11:06 PM | #7 |
One more tip would be to throw a couple greased up washers between the nut and the axle flange, it will make it easier as well as reduce the risk of spinning the stud in the flange and wrecking the pressure fit that keeps them in.
67 Chevy C10 67 Chevy Camaro 95 Chevy Camaro Z28 10 GMC Sierra |
06-09-2011, 11:41 PM | #8 |
Happy to be here
I usually put a not on the stud that is large enough to slide on without touching the threads. This prevents the lug nut from biting in to the axle flange. A light coat of anti-seize will help prevent friction while seating the stud.
06-10-2011, 12:05 AM | #9 |
Registered Cruiser
Sounds like a good idea with the washer or oversized nut, thanks!
