Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Closed Thread
Old 07-22-2011, 09:04 PM   #1
chevytrucksonly
chevytrucksonly's Avatar
Parting 94 - C2500 6.5 TD
108,000 K on truck
The 4l80e Transmission blew out.
-$550 plus s/h - 1 year old Custom leather Buckets and console/jumper seat (can be dyed to another color with spray dye). They are designed to OEM specs for mounting to an existing GM bench or bucket seat threaded bolt patterns in the floor. He paid $1400 new for seat setup-ouch!
-All other interior pieces are in great shape.
-$80 plus s/h - Set of gray/charcoal door panels – Great shape.
-$20 each - shipped- Door Panel power window and lock switches
-Has a 6.5 TD F Code-290 HP. It will be sold as breakdown or a rebuild; I have 2 more of these engines in my shop. So if you need heads, block, crank etc let me know.
1) $225 plus s/h –Turbo Charger GM – 4
2) $90 plus s/h – Turbo exhaust
Many other diesel parts.
-$35 plus s/h - Each fender has one dent near front but was sand blasted primed and rubberized/undercoated on inside of fender and in seams.
-R door has one dent (hand size)
- The hood has 3 small pings in front curve and is a red color with stripe on it-but otherwise in great shape.
-$85 plus S/H - Tailgate has 2 small pings at top and again is a different color-blue
-$90 plus s/h - Overhead on cab clearance lights
-$450 local pick up - Short wheel base Z71 Bed-perfect condition.
He was about to paint and put another bed on it and more custom work to the frame and exterior.
-$325 local p/u - Rear Axle 8 - LUG 4.10 RATIO 4.10R (GT5)
-$50 plus s/h - Line-x Sprayed Mirrors
-BUMPER AND WINCH ARE STAYING.
Also parting 88 k1500 Silverado 4x4, Auto, 350c.i – left front end wreck damage.
Let me know specifically what you need and I will post or pm you back with the cost and include zip for shipping.
Payments through PayPal unless other arrangements are made. Local pickup available, shipped from 30528.
Michael D
1990 Chevy Z71 K1550
1993-K2500 Cummins 6BT_NV4500 5 Speed
www.chevycumminstruck.com
Technical Data and GM Parts diagrams for 88-98
chevytrucksonly is offline
Old 07-24-2011, 01:38 PM   #2
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
Re: Parting 94 - C2500 6.5 TD
Do you have a complete tubro set up? i am looking at putting a 6.5 turbo set-up on my cucv.
BIGCHEVYMAN is offline
Old 07-24-2011, 02:42 PM   #3
chevytrucksonly
Re: Turbo
I do have a couple of setups. includes gm4 turbo and hardware,turbo exhaust, Turbo tube drain, exhaust crossover, breather unit , upper and lower intakes and downpipe to connect to your exhaust-everything. Around $600 or less. Sometimes a valve cover is required depending on year of 6.2, if needed I'll give you one.
I can give you a firm price If you would tell me what year the truck is and year of the 6.2.
Michael
Old 07-24-2011, 04:51 PM   #4
70BLAZERX2
get the 4L80E wire harness and stand alone computer for it..
I dont need it but someone out there will
That is a hard item to find for a 4L80E conversion in an early truck..
That will move fast also. It is supposed to be a seperate harness from the engine..and works on the TPS to shift.
70BLAZERX2 is offline
Old 07-24-2011, 05:42 PM   #5
chevytrucksonly
Re: Tcm and harness
Thanks for the input. They are difficult to locate but I do have 2 of them I'm holding on to to use with a conversion from elect fuel injection(94 and up 6.5) to mechanical fuel injection (93 and down on the 6.5 and 6.2 diesels). The efi had many problems and cost a lot $ to repair or replace. There's an aftermarket trans computer that will do the same thing even better-but it cost around $700
Michael D
Old 07-24-2011, 06:52 PM   #6
BarryB
BarryB's Avatar
What about the guages on the pillar with the pillar mount? With the sending units? and what are they for trans temp, boost, etc.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline
Old 07-25-2011, 05:13 AM   #7
chevytrucksonly
They have been sold already, sorry,
Michael
Old 07-25-2011, 03:52 PM   #8
BarryB
BarryB's Avatar
How bad is the motor, I assume it had to have been running when the tranny blew out. I have a friend that is looking for a good running 6.5 to put in his 92. If so,How much ?
Two rules in life.
BarryB is offline
Old 07-25-2011, 07:34 PM   #9
Kurt L
Kurt L's Avatar
What bout the bezel? do you still have it? if so how much plus S&H to 32218.
Kurt L is offline
Old 07-26-2011, 03:24 AM   #10
chevytrucksonly
The bezel around the the instrument cluster, just trying to make sure I know exactly what piece your needing. There's a couple of old pics below if that helps, if not tell me exactly where it is.
Michael
Old 07-26-2011, 04:34 PM   #11
Kurt L
Kurt L's Avatar
ywah thats the one the second pic. i need the screws also.
Kurt L is offline
Old 07-27-2011, 07:11 AM   #12
chevytrucksonly
Let me get shipping cost and PM you later today with cost-I've got some screw I will need to locate.
Michael D
Closed Thread
