Old 08-19-2011, 10:32 AM   #1
corvettejim1968
corvettejim1968's Avatar
a couple questions
i want to add the original tach and vacuum gauges in their respective places in my dash cluster. my truck still has the original 230 six do you think these gauges will work fine with the six?
also the truck came with three on the tree and now it has the th350. the gear indicator is for the power glide do you know if they make an indicator with L , 2 , and D that will look good on the 65 column. thank you
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-19-2011, 11:03 AM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: a couple questions
markeb01 has a great thread on Sun Tach's
http://67-72chevytrucks.com/vboard/s...d.php?t=392461
The vaccum gauge will work on the six no problem.
1966 had an optional 3 speed automatic. This gear selector prism may not line up with the newer 3 speed positioning however. Perhaps if you look in the 67-72 restoration places you might find a 3 speed clear prism for your shifter but I'm not sure it was the same style, anyone have an idea?
Old 08-19-2011, 11:35 AM   #3
yelmer
i have 66 3sp auto the L1, L2 D IS WHAT I HAVE
yelmer is offline   Reply With Quote
Old 08-19-2011, 11:04 PM   #4
Rich 5150 69
Rich 5150 69's Avatar
Have you tried..http://www.ididitinc.com/accessory_pages/sh.htm
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-20-2011, 12:54 AM   #5
corvettejim1968
thanks for the link.
Old 08-20-2011, 11:20 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
I'm going to be dealing with that same issue, but with a 700R4. I don't think there's enough room in the lens for that many gears.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 08-20-2011, 11:59 AM   #7
oem4me
66's equipped with the th400 (mostly Custom Campers) had a three speed auto indicator like the one below.
