Old 08-25-2011, 05:42 PM   #1
Glennerd
Glennerd's Avatar
72 GMC single lamp dual beam headlights
Does anyone know of a headlight that will fit and offers both high and low beam? I want to build a cold air intake that will use the inner or high beam location of my headlights. (similar to the ford thunderbolt). Thank you.
Glennerd is offline   Reply With Quote
Old 08-25-2011, 06:51 PM   #2
463
463's Avatar
Re: 72 GMC single lamp dual beam headlights
your low beam is a dual element bulb and will work as you are wanting it to but with reduced light output on the road. chev used a two single 7 1/4in duel element bulbs and gm used the four bulbs in a 5 1/4 in
Trueman
463 is offline   Reply With Quote
Old 10-05-2011, 08:13 PM   #3
Glennerd
Glennerd's Avatar
So far, so good.
Old 10-05-2011, 08:25 PM   #4
Mike C
Mike C's Avatar
You can get small diameter dual filament bulbs form European suppliers. Cibie makes them, and Hella probably does, too. Make sure you get right hand drive ones! The reflectors internally are different for L or R hand drive. I've seen this come up with guys who have WWII MB jeeps who are looking for 12v lights. You also may be able to find some motorcycle lights which is what my MB has in it.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-05-2011, 08:54 PM   #5
Glennerd
Glennerd's Avatar
Cool. Been wondering if bike lights would work. The web kept sending me to motorcycle sites when I was looking for lights. Seems some Harley lamps may work, but I won't pay for that name on a light anytime soon, lol
Old 10-05-2011, 09:18 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Here's just one supplier.... Google will probably find more. http://www.rallylights.com/detail.aspx?ID=351
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 10-05-2011, 09:57 PM   #7
Glennerd
Glennerd's Avatar
Thanks, Stocker. A buddy of mine was suggesting going with a bulbless lamp and using an HID system for max lighting. This looks as if it will do the trick. Awesome!
Old 10-05-2011, 11:25 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Looking at that link, it appears to be a sealed-beam lamp. Not what I had in mind (sorry) -- I didn't think Hella even made those....
That site does carry E-code lamps, though, and that's what I would choose over sealed-beam any day.
This looks like the right ones: http://www.rallylights.com/detail.aspx?ID=733 I have not found a need for higher-wattage (and more costly) bulbs. The 5006A - 60/55W Hella bulbs (H4) work very well.
You could call 'em for more info.... I've dealt with them before, they're very helpful.
If you want a true bi-xenon HID, I think you'll end up paying quite a bit more. That's something I've never really looked into, though.
- Mike -
RIP El Jay
