Old 09-12-2011, 01:28 PM   #1
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
Speedo cable makin noises
How do i go about fixing it because its annoying the hell out of me
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 09-12-2011, 02:08 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: Speedo cable makin noises
replace it!
i have also heard that you can lubricate the speedo cable with graphite, but i don't really understand how you can get the core out without ruining the cable.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 09-12-2011, 03:14 PM   #3
jdheff1982
The core can be pulled and re-lubed if it is in good shape.
You can pull the core either from the tranny or behind the speedo in the dash.
*Recommended method is to unhook both ends
*Pull the core out
*Examine core for any protrusions or kinks. If any are found, replace.
*Otherwise, get some sort of cleaner (W-40) and squirt down the tube from behind speedo until it runs clear.
*Next, take some white lithium grease and spray it into the palm of one of your hands.
*Run the core thru that hand so that it is thoroughly coated.
*Carefully run the core back thru the cable
*Rehook and test it.
*If it still makes noise, the tubing might need replacing or the speedo it self needs some work.
Hope this helps.
Project and Truck Specs: http://67-72chevytrucks.com/vboard/s...d.php?t=483381
jdheff1982 is offline   Reply With Quote
