Old 10-05-2011, 07:30 AM   #1
hugger6933
5 hole change overs what did you do with
the rear axles? If you got redrill or change over axles or what, tell what you did. I have change over stuff for my 68 and my first 70 are covered . It is my last 70 that came in last week ,I don't have the rear stuff for it. I have a rolling 76 frame I could get the front and do a crossmember change over.
hugger6933 is offline   Reply With Quote
Old 10-05-2011, 09:15 AM   #2
'Mater
'Mater's Avatar
Re: 5 hole change overs what did you do with
I have real leafs so swapped the entire rearend with the one from the same truck that the front came off of. Had to swap over the shock mounts and bump stops from the '67. Just a couple hours work if you have good welder handy.
'Mater is offline   Reply With Quote
Old 10-05-2011, 10:16 AM   #3
bmfm64
bmfm64's Avatar
I used a 71 rearend.
bmfm64 is offline   Reply With Quote
Old 10-05-2011, 09:04 PM   #4
hugger6933
Well, that is what I did on my 68 GMC and my other 70 that I change both from longs to shorts and 8 hole [GMC] and 6 holes[70 c-10] to 5 . Now I am out of extra trucks to get suspesions off of
Old 10-05-2011, 09:18 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
used a 71 rearend to
John
1999 Toyota Tacoma 4x4
Old 10-06-2011, 11:17 AM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
I got some weld on traing arm mounts and adjustable panhard bar and used the 3.73 posi from the 76 that I used the front suuspension from.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-06-2011, 12:23 PM   #7
Shane
Shane's Avatar
you can also replace the axles ... I think ECC offers them.
Shane is offline   Reply With Quote
