Old 11-06-2011, 10:50 AM   #1
no moa
no moa's Avatar
Disc rears
I have a 71 c10 12 bolt, and I want to switch to disc in the rear. I have all new in the front , with pb master and porportioning valve. I can't afford the whole wildwood kit.
Recommodations? Or stay clear offs? I did a search, but there is no direct answers to my questions.
Thanks.
Glen
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 11-06-2011, 11:20 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc rears
The most economical way is to use a set of brackets on your stock axle. They can be found in our Vendor Marketplace where CaptFab sells them. The down side is they do not have E-brake provisions.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-06-2011, 11:30 AM   #3
no moa
no moa's Avatar
Re: Disc rears
Darn I need ebrakes. I'll keep searching. Thanks.
Old 12-02-2011, 08:44 PM   #4
jbice70gmc
jbice70gmc's Avatar
Re: Disc rears
I got a set of the brackets from captainfab and bought some camaro calipers and the mounting brackets that you bolt up to the captainfab brackets for $75 from a salvage yard.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 12-03-2011, 03:14 AM   #5
jbice70gmc
jbice70gmc's Avatar
Re: Disc rears
Camaro calipers have the ebrake.
Old 12-03-2011, 06:51 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Disc rears
Summit Racing sells a complete rear disc brake kit from SSBC.
(e-brake included)
Very reasonably priced.
Keith
Convert to disc brakes.
Old 12-03-2011, 07:14 AM   #7
dmwphoto
dmwphoto's Avatar
Re: Disc rears
(e-brake included)
i am searching on summit now and cant find that. can you give a link?
dmwphoto is offline   Reply With Quote
Old 12-03-2011, 07:49 AM   #8
lolife99
lolife99's Avatar
Re: Disc rears
http://www.summitracing.com/parts/SSB-A126-1/
Keith
Old 12-03-2011, 07:59 AM   #9
dmwphoto
dmwphoto's Avatar
Re: Disc rears
found that one but it says for 73-87. thanks for posting the link though
Old 12-03-2011, 08:18 AM   #10
lolife99
lolife99's Avatar
Re: Disc rears
EDIT:
Here's the application guide from SSBC's website:
•1974-1991 Chevrolet Blazer C10
•1971-1987 Chevrolet C10 Pickup
•1974-1991 Chevrolet Suburban C10
•1970-1987 GMC C10 Pickup
•1973-1982 GMC Jimmy (Fullsize 2WD)
•1974-1991 GMC Suburban C10
http://www.ssbrakes.com/commerce/det....cfm?nPID=8363
Axle flange dimensions:
Keith
Old 12-03-2011, 08:22 AM   #11
dmwphoto
dmwphoto's Avatar
Re: Disc rears
thanks Keith
Old 12-03-2011, 08:43 AM   #12
no moa
no moa's Avatar
Re: Disc rears
Cool thanks for the link and the info. I have found the Wilwood rear kit for $689.00 i think it was. so i decided I'm saving up for that and the fronts.
Old 12-30-2011, 10:36 AM   #13
BuiltwithIvy
Re: Disc rears
You can go a lot cheaper if you look around at the kits on ebay and piece the parts together, I think I spent 250 for everything needed, and another 50 to get my axles machined down for the rotors
"To speak of the art of one loom, the art of one river, the art of one tractor, or the art of one automobile is not preposterous; it is to point to the size and importance of the gap between general knowledge and situated knowledge" - James C. Scott
1969 C10 - http://67-72chevytrucks.com/vboard/s...d.php?t=492064
1930 Tudor Sedan
BuiltwithIvy is offline   Reply With Quote
Old 12-30-2011, 12:42 PM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Disc rears
Another option is the McGaughys set up. Its probably the best value for a 13" conversion on the market. Several of our Forum Vendors sell McGaughys product, so check the Suspension Marketplace or the Vendor Marketplace for the best deals.
Articles-
"Refining Sierra"
Old 12-30-2011, 03:12 PM   #15
no moa
no moa's Avatar
Re: Disc rears
Thanks guys, i'm saving up for the Wilwood kits, it will be awhile, but it think it will be worth it.
