Old 11-19-2011, 08:22 PM   #1
jbice70gmc
jbice70gmc's Avatar
With shock relocators and without.
Looking for feed back on you guys running shock relocators and you guys who are running without. Hows the ride?
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 11-19-2011, 08:31 PM   #2
BMERDOC
BMERDOC's Avatar
Re: With shock relocators and without.
I lowered mine 3/5 and haven't relocated the shocks yet. Its only been on butter smooth roads so its been ok. I know that I'll have to relocate them to get the 3" (2 inches was from blocks) loss back and to fix the lean in. I read a thread that stated that they will not work correctly at 30º or more. I am in the midst of modifying some shock brackets like member Scoti did.
http://67-72chevytrucks.com/vboard/s...d.php?t=359399
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 11-19-2011, 08:36 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Want to know as well. I have 5" springs with 1" blocks out back and the shocks are laying over pretty far. I have the relocators just haven't put them in yet. If I do anytime soon I will post the results. Right now the ride is ok but the axle does hit the bump stops on moderate to heavy bumps. Hope that will stop once I install the shock relocators so I don't have to c-notch.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-19-2011, 08:40 PM   #4
BMERDOC
BMERDOC's Avatar
I has the same bumpstop problem and trimmed them so they were a 1/4" lower than the frame (to protect the frame) and now no more bottoming.
Nick Carter
Old 11-19-2011, 09:20 PM   #5
jbice70gmc
jbice70gmc's Avatar
My truck will be on air bags with 2.5 drop spindles up front and a C notch in the rear with 2" drop blocks.
Old 12-04-2011, 10:12 AM   #6
shawno72
C/10 junkie
shawno72's Avatar
Ok I installed my rear shock relocators yesterday and took the truck for a good long drive. First off let me say what an improvement on the ride. Much much better and softer ride. I wish I had done this at the time I lowered my truck. I must say if you are lowering your truck you must use the relocators to get the best ride.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 12-04-2011, 12:32 PM   #7
jbice70gmc
jbice70gmc's Avatar
OK I appreciate the feed back shawno I have acctually questioned robnolimit on another thread about the no limit shock relocators and will be going with those.
