04-19-2003, 07:38 PM | #1 |
Member since 2000
Hei........???!!???
Well i had her back firing, and now there not even a spark, there is power running into her ,but no spark. what can it be?
04-19-2003, 07:39 PM | #2 |
68cst_ss490
the dizzy is in 180 degrees out, pull it out spin the rotor 180 and pop it back in
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
04-19-2003, 07:57 PM | #3 |
Member since 2000
Well let me tell you about todays HEi adventure.........When i had her back firing i thought it was 180 off so i got the thing to TDC and then i fliped her around. I puled out the plug and got a friend to crank it. No spark.......I had the edge of it on the head so it could have a negative. I stuck the tester in the wire plug and cranked it and nothing agian. ????
04-19-2003, 08:00 PM | #4 |
Grubbin'
If you can find one, get the plastic top that pops over the plugs to tell you which wire goes to each cylinder. Sometimes, you will encounter the problem your having just by having two wires switched out of order. Recheck the wires and top dead center on the dizzy and try again.
project rust attack 1969 Chevrolet LWB w/ 307. I got power steering now woohooooo!!!!!!! |
04-19-2003, 08:29 PM | #5 |
Alexis check the info at this link. They can do a better job of explaining than I can.
http://www.chevelles.com/techref/tecref5.html Hope it helps. Good Luck............Stroker
72 SWB parts and pieces Oklahoma Last edited by Stroker; 04-19-2003 at 08:34 PM. |
04-19-2003, 08:34 PM | #6 |
Member since 2000
ok is the harmonic balancer suppose to point to "0" on that little dial thing thats mounted to the motor or straight up? just so i can clear this thought out of my head.
04-19-2003, 08:40 PM | #7 |
If your balancer and tmming tab are correct the 0 should line up. Also take out your #1 plug and hold you finger over the sparkplug hole when there is pressure comming out and the tab and balancer line up you should be at TDC for #1.
72 SWB parts and pieces Oklahoma |
04-19-2003, 08:55 PM | #8 |
Member since 2000
just foud out why it wasn't firing.....toasted coil. i replaced it and wala.......still need to work the timing situation out. My batterys dead so i got to wait for the starter help thing to recharge
04-20-2003, 10:51 AM | #9 |
Make sure the wiring on the cap is right.
On a stock point cap the #1 is not in the same spot as the HEI, and I've seen several people try to do it.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
04-20-2003, 10:55 AM | #10 |
#1 can be anywhere on the cap as long as the #1 wire goes to it when the #1 cylinder is at tdc.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
