Old 11-26-2011, 04:11 AM   #1
wannagettachevy
wannagettachevy's Avatar
Z question
2 questions for you Z'd guys.
1. Considering the motor and trans will essentially be higher than the rest of the frame after a z, what mods to the tranny crossmember are required, if any?
2. How much modification to the cab is required with 2 1/2" or 3" z? any?
Thanks BROS!
wannagettachevy is offline   Reply With Quote
Old 11-26-2011, 04:41 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Z question
The tranny will need to go up the same amount as the motor.
2.5" Z will require you to raise the transmission the same amount.
(2.5")
Some people use the larger 4x4 high hump floor pans.
This will allow you to run stock oem style carpet or floor mat.
But I doubt it's enough to work for that tall of a "Z".
Most likely you will need to add a tunnel for the driveshaft also.
Keith
Convert to disc brakes.
Old 11-26-2011, 01:14 PM   #3
SCOTI
SCOTI's Avatar
Re: Z question
(2.5")
If the drivetrain can be shifted forward some, it can help w/cab clearance issues. Too much though & it will create core support clearance issues....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
