Old 11-30-2011, 12:18 AM   #1
rich67
rich67's Avatar
rearend search/ what to use
i"m building a swb 67. want to go with a 12 bolt for strentgh. would like to stay with 5lug since i have a newer model 5lug disc for front. havent done anything yet so completely new ideas are ok. would also like to hear opinions on the best shocks for your money since im doin doin bags yet. coil spring truck. also have 6lug fronts and rears and 8lug fronts and rears at my disposal. any help, opinions or ideas appreciated. thanx rich
rich67 is offline   Reply With Quote
Old 11-30-2011, 12:21 AM   #2
rich67
rich67's Avatar
Re: rearend search/ what to use
also arent 71-72 5lugs wider than my 67? or am i backwards? and will car 12bolts work?
Old 11-30-2011, 12:57 AM   #3
leftcoast66
leftcoast66's Avatar
I believe its 73 and newer is wider by an inch and a half or so, can't remember exact number. 71 and 72 are 5 lug but same diameter as the earlier 6 lugs. I hope that helps.
leftcoast66 is offline   Reply With Quote
Old 11-30-2011, 01:06 AM   #4
rich67
rich67's Avatar
that narrows down to finding a close 71-72. that way only have to convert rear to disc. thanx for info dude.
Old 11-30-2011, 01:53 AM   #5
gearys 5600
gearys 5600's Avatar
Actually..The 71-72 rearends are a little wider than the 67-70
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-30-2011, 02:16 AM   #6
rich67
rich67's Avatar
1-1/2" i thoought i read somewhere on the site. what would stop a guy from taking his axles from his ho52 or dana 60 to the machine shop and have them redrilled for five lug?
Old 11-30-2011, 12:05 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Redrill axles
conversion axles
swap 71 72 rearend (bolts in)
Or fab in a 73-87 (gotta weld perches)
John
1999 Toyota Tacoma 4x4
Old 11-30-2011, 01:25 PM   #8
jbice70gmc
jbice70gmc's Avatar
Actually they made the narrower rearends half way through 70 and then started putting the 1 1/2" wider rearends in. So if you find a 70 model make sure you measure.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 11-30-2011, 01:31 PM   #9
rich67
rich67's Avatar
they wouldnt be five bolt though would they?
Old 11-30-2011, 01:38 PM   #10
67swb72klb
67swb72klb's Avatar
5 stud started in 71 with the disc breaks
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-30-2011, 01:49 PM   #11
jbice70gmc
jbice70gmc's Avatar
No your right the narrower rearends are 6 lug. I just had to order new axels from Moser because I have 5x5 wheels also. $245.00 for the axels. But there are lots of people here on this site that have the wider rearends with really nice wheels. Just have to get wheels with the proper backspacing.
Old 11-30-2011, 03:58 PM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
63-early 70: narrow 6-lug
Late 70: wide (.75" per side) 6-lug
71-72: wide 5-lug
73-80: wide 5-lug (leaf)
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-01-2011, 01:12 AM   #13
rich67
rich67's Avatar
so i could run a 71-72 5 lug 12 bolt and get wheels with 3/4 inch deeper back spacing correct? duh! never payed attention to the backspacing talk. all makes sense now! the lite bulb always works, just sometimes somebody else has to pull the chain! thanx folks, rich
Old 12-01-2011, 01:54 AM   #14
54Caddy
GM Addicted
54Caddy's Avatar
the only thing with that wider rear end if you want the rim to have more lip its harder to do wont tuck as easy.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is online now   Reply With Quote
Old 12-01-2011, 01:56 AM   #15
rich67
rich67's Avatar
behind wheel arches?
Old 12-01-2011, 02:03 AM   #16
rich67
rich67's Avatar
if larger backset used, wouldnt that take you back to factory outside to outside of wheels?
Old 12-01-2011, 12:55 PM   #17
gringoloco
A guy with a truck
gringoloco's Avatar
Yes, it would. Just remember, whatever you add to the back gets removed from the front, hence the shallower lip.
-Chris
Old 12-01-2011, 01:27 PM   #18
rich67
rich67's Avatar
So if i go with a widerwheel in the back would have to go with even larger backset to keep wheels lined up correct? I know this seems simple but buyin the parts and dont want to get wrong stuff. Got enuff of that stuff!
Old 12-01-2011, 01:50 PM   #19
Ackattack
Ackattack's Avatar
When I was restoring my 68 it came with a 72 5 lug rear, so that's what I used. I rebuilt it with new bearings, seals, new posi unit.
I wish I would have just gone with a 9". Shortened to where I wanted it, and then had new axles made with a 5x5 pattern. That's what I'd do if I could do it over again.
Ackattack is offline   Reply With Quote
Old 12-01-2011, 05:27 PM   #20
kieth
kieth's Avatar
I just had the machine shop drill my 6 lug rear axles and put 5 lug in it. The center of the axle hub has to be turned down also......when I did my front brake conversion we got the correct 5 lug pattern and life was good, and it did not cost very much. Kieth
kieth is offline   Reply With Quote
