Old 12-01-2011, 11:05 PM   #1
Mr.C
Mr.C's Avatar
Manual to power break conversion
Question: In a 71 C10 with manual breaks will I just need to add a booster and proportioning valve to upgrade to power, or will I also need a new master cylinder? Also who has the best stuff out there for the money?
Thanks in advance, Mike
How about you go over and introduce yourself, build me up, that way I don't have to brag about myself later.
Mr.C is offline   Reply With Quote
Old 12-02-2011, 02:39 PM   #2
fuzzy1nickels
Re: Manual to power break conversion
I honestly found it to be easier to rip off a front cross member with power disk already on it, and steal the master cylinder while you're at it.
If you buy a 73 set of disk brakes with spindles from a wrecking yard you can pick up parts from your local auto store to do most of the conversions, and fat man fab sells the adjusting sleeves you need.
and you can also go the route of CPP, and get the full conversion kit. All depends on your budget and such.
fuzzy1nickels is offline   Reply With Quote
