Old 04-24-2003, 05:36 PM   #1
hughnews1
wow 16.5" tires
16.5 tires
Part # Size/Description $/Tire Sidewall Availability
03530 9.50R16.5 Michelin XPS Rib 10 Ply $201.99 Black Sidewall Limited
286494 9.50R16.5LT 8 Ply Firestone Steeltex Radial A/T $104.99 Black Sidewall Good
87493 LT9.50R16.5 Uniroyal Laredo AWP 8 Ply $102.99 Black Sidewall Good
42684 9.50R16.5 116Q BF Goodrich Commercial T/A 8 Ply $117.99 Black Sidewall Good
47773 LT9.5/R16.5D 116/112Q Uniroyal Laredo HD/H W/ Nailgard $133.99 Black Sidewall Limited
56952 LT9.50R16.5D 116/112Q Uniroyal Laredo HD/H $117.99 Black Sidewall Limited
43837 9.50R16.5D Cavalier A/P $90.99 Black Sidewall Good
24416 9.50R16.5 Radial All Season King $85.99 Black Sidewall Good
101613 LT9.50R16.5 Dunlop Radial Rover A/T $105.99 Black Sidewall Good
752240300 950R16.5D Goodyear Workhorse XG Radial $114.99 Black Sidewall Limited
312218090 950-165 Bias Goodyear Workhorse Rib E $99.99 Black Sidewall Limited
313217091 950-165 Bias Goodyear Workhorse M&S D $99.99 Black Sidewall Limited
312217090 950-165 Bias Goodyear Workhorse Rib D $89.99 Black Sidewall Limited
291730 9.50R16.5 Bridgestone R273 SWP $184.99 Black Sidewall Limited
292311 9.50R16.5 Bridgestone M773 SWP $183.99 Black Sidewall Limited
292303 9.50R16.5 Bridgestone M773 SWP $180.99 Black Sidewall Limited
267686 950R16.5 Bridgestone R-260 $176.99 Black Sidewall Limited
291722 9.50R16.5 Bridgestone R273 SWP $175.99 Black Sidewall Limited
286508 9.50R16.5LT 10 Ply Firestone Steeltex Radial A/T $109.99 Black Sidewall Good
281859 9.50R16.5LT 10 Ply Firestone Steeltex Radial R4S $97.99 Black Sidewall Good
281832 9.50R16.5LT 8 Ply Firestone Steeltex Radial R4S $94.99 Black Sidewall Good
282332 9.50-16.5LT 8 Ply Firestone Trans Trac LT Bias $79.99 Black Sidewall Good
282278 9.50-16.5LT 8 Ply Firestone Trans Rib Light Truck Bias $74.99 Black Sidewall Good
hughnews1 is offline   Reply With Quote
Old 04-24-2003, 07:09 PM   #2
cheyenne10
cheyenne10's Avatar
where did you get info.
Curious where you got complete detail listing? I am in market for good 235/75/16 or 265/85/16 load range E's for burban and need to do some shopping. Any recommendations?
Bob
cheyenne10 is offline   Reply With Quote
Old 04-24-2003, 07:28 PM   #3
hughnews1
etire.com try them
Old 04-24-2003, 08:16 PM   #4
68CST327
Ahhh! $200 a tire to replace my Michelins! Good thing I'm switching to 16" wheels soon.
68CST327 is offline   Reply With Quote
Old 04-24-2003, 11:50 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It is pretty much crazy to look at 16.5s IMO.
My bias ply 16.5s will be burn out tires, and the 2 good steel belt 16.5s are real good spares.
Old 04-25-2003, 04:16 AM   #6
low 84
low 84's Avatar
Re: wow 16.5" tires
Originally posted by hughnews1
16.5 tires
those are some heavy duty biatches a very good tire imo
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 04-25-2003, 04:45 AM   #7
68CST327
Those are what I have on my truck right now, and yes, they are very good tires, but they are showing signs of age from sitting outside for years.
Old 04-25-2003, 09:25 AM   #8
nightmare
nightmare's Avatar
i just replaced 2 of my 16.5's this past week. went to a 18 wheeler tire shop. the guy was just wanting to get rid of them, so for $65 a piece, i took 2 8.75 x 16.5's home. not bad in my opinion. everywhere else i went, they either couldn't find any, or it was going to be a week or so before they could get any. not only that, they were about twice as much.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 04-26-2003, 02:35 PM   #9
hughnews1
just back from Pep boys store in rochester ny found 9.50 x16.5" tires only $ 80.99 !!!!!! go pep boys ..
Old 04-27-2003, 12:50 AM   #10
Solarus1981
why not put 15's on them?
'67 LWB C-10, 406 cid th350, dunno what rear end
Looking to rent a house in Puget Sound area, anyone have one?
Solarus1981 is offline   Reply With Quote
Old 04-27-2003, 07:38 AM   #11
hughnews1
way too much $$$ and work to change 8 - 5 lugs wheels ...
Old 04-27-2003, 01:20 PM   #12
Longhorn Man
And illegal in some states. You put 15 inch tires on a truck that is ment to carry more weight than the tire was designed for and it becomes a liaility issue for the company that built the rim.
Old 04-27-2003, 03:54 PM   #13
Solarus1981
But, dont some ***d and Dodge 1tons come with 15's? Also... who says you have to change the lugs? 15's come in all different lug patterns.... (dont know if they come in 8 lug @ 15" though...)
