Old 01-10-2012, 09:57 AM   #1
Pizzalovr36
hey guys can i see some stepside rear tires?
just wanna see some shortbed stepside with some rear tires for me to figure out what i want!
Pizzalovr36 is offline   Reply With Quote
Old 01-10-2012, 03:31 PM   #2
68Stepbed
68Stepbed's Avatar
Re: hey guys can i see some stepside rear tires?
What are you interested in? You can look through my photobucket pages. I currently have 17x9.5 wheels(5.5" bs with 7/16" spacer) with 275/55/17 tires. My old setup was 15x8 wheels with 275/60/15 tires.
http://s221.photobucket.com/albums/d...ick68/My%2068/
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-10-2012, 03:35 PM   #3
Pizzalovr36
did it rub at all with the 275's on the 15s?
Old 01-10-2012, 03:38 PM   #4
68Stepbed
68Stepbed's Avatar
Not even close. The 17's rubbed on the inside because the backspacing is too deep. That's why I'm running spacers. I should've ordered 5" backspacing to start with
The 15's had 3.75" bs.
Matt
Old 01-10-2012, 03:50 PM   #5
Pizzalovr36
what about sticking out of the fender well?
Old 01-10-2012, 05:11 PM   #6
68Stepbed
68Stepbed's Avatar
No they fit inside the fender just right. You will have to be carful running 15x10's though. If the backspacing isn't right, they will poke out. 4.75" backspace would be perfect backspace on a 15x10.
Matt
Old 01-10-2012, 07:07 PM   #7
Iron Hauler
Iron Hauler's Avatar
What is the distance from fender lip to fender lip on a stepside?
Iron Hauler is offline   Reply With Quote
Old 01-10-2012, 08:15 PM   #8
darkhorse970
darkhorse970's Avatar
Are you running the stock '68 rearend that has been converted to 5 lug or is it a wider 5 lug rearend?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 01-10-2012, 08:52 PM   #9
71STPSDE
71STPSDE's Avatar
I've got 17 X 10 rims with 285/55 tires and no rub. I'll take some pics tomorrow.
71 Chevy Stepside
377/350
71STPSDE is offline   Reply With Quote
Old 01-11-2012, 10:08 AM   #10
68Stepbed
68Stepbed's Avatar
It's the wider 72 rear.
Where did you get the 285 tires? We need pics.
I've never measured.
Matt
Old 01-11-2012, 10:44 AM   #11
CC69Rat
CC69Rat's Avatar
About 11" - without any trimming. This is going to be close, but may be different from truck to truck. I layed a step fender down on the garage floor and measured from the floor to the fender lip. (garage floor would simulate the bedside) This is absolute max. My tires are 255/45/20 but my truck will be dropped about 7". (more coming soon) It's about 5" now with no wood in the bed, etc. My rear tires are 20x8.5 with 4.75" BS. I have the 68 rear end too.
The earlier rear end is 55.5" plate to plate. The later rear end is 57" plate to plate. So, if you have the later rear end you could run .75" more BS than I do. (1.5" total width difference) But it would make the wheel look .75 narrower on each side. (less lip on the outside as the rear housing width would 'eat up' that .75" of wheel lip) Still the same width wheel, it just sits back .75" further.
How low is your truck? You going with 15's, 17's, 20's + ? ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-11-2012, 11:10 AM   #12
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I wanted the old school look of big steam rollers sticking out so here's mine.
The wheels are 15 X 10 with a 3.5 backspace. Tires are 275/60/R15. I recently swapped the tires to 295/50/R15. They are a little smaller in diameter and a bit wider tread.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
