Old 01-10-2012, 11:42 PM   #1
rsavage
rsavage's Avatar
AC Hose Replacement
Anyone have any experience/tips on replacing the ac hoses? It appears that the original hoses are crimped (soldered?) to the aluminum tubing. If I remove the ends will I find barbed tubing that I can clamp new refrigerant hose onto?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 01-11-2012, 12:11 AM   #2
Rooster's 67
Rooster's 67's Avatar
Re: AC Hose Replacement
Best bet would to find a hose shop that can replace the hoses, that way they can install new fureles and crimp them. they seal with even pressure around the dia of the hose.
But yes you should find barbs on the factory hoses.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-11-2012, 01:39 AM   #3
allchevy58
allchevy58's Avatar
Old Air Products has new ones that fit perfect. If you have someone cut and put new hose and fittings on, they won't fit correctly in the hold down clamps.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 01-11-2012, 04:24 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: AC Hose Replacement
Go to a automative AC shop and have them do the hoses and connections. You will be glad you did. If the hoses need ends the hoses need to be replaced also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2012, 11:30 AM   #5
eagleuh1
eagleuh1's Avatar
Docs Blocks sells the clamp on type hose and clamps, as well as the tool to install the clamps. Don't know if they'll have the exact size hose though. Good luck. Also, be carefull removing old hose that you don't knick the tubing with aknife or tools. Causes leaks real easy. Jim
eagleuh1 is offline   Reply With Quote
