Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-11-2012, 02:43 PM   #1
davepl
davepl's Avatar
Temp gauge always reads low - what's the right resistance for the sender?
My 70 402 has gauges and the Temp gauge always reads down near Cold. Not -at- cold as in not working at all, but very low.
The connection is OK, but I'm wondering what the ohm range is supposed to be on the sender. If the truck is up to operating range (let's say 195) what's the ohmmeter supposed to show? If someone knows that value, I can check it to find out if its the sender or the gauge.
Thanks for any help!
Dave
davepl is offline   Reply With Quote
Old 01-11-2012, 03:15 PM   #2
fixit-p
fixit-p's Avatar
Re: Temp gauge always reads low - what's the right resistance for the sender?
I don't know the specs on the sender but if too much sealant is used it could lead to high resistance between sender body and engine which would be additive to the resistance of the sender. So I would check resistance between sender body and engine.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 01-11-2012, 03:53 PM   #3
cdowns
cdowns's Avatar
having sender in the intake manifold at times leaves the sender not in contact with coolant causing bad readings
Old 01-11-2012, 04:25 PM   #4
davepl
davepl's Avatar
Thanks! I'll check the sensor-ground differential and report back. Good ideas!
This one is in the head. On my 427 2+2 (Impala) it's in the intake. Had to drill and tap it when I replaced the intake... $40 for the bit and tap, cost more than the intake!
