01-14-2012, 06:56 PM | #1 |
12 bolt differential ratio?
Finnally got to change my differential oil this weekend, had 14 X 43 stamped on the ring gear, after counting both gears I was satisified it was a 307: 1 differential. Question is I thought these came in 308 ratios ? Whats up?
01-14-2012, 08:57 PM | #2 |
Re: 12 bolt differential ratio?
I think a 3.08 in a 12 bolt is a 40-13 tooth count. Are you sure it's a GM 12 bolt? Sounds like a Dana 30 and would be a 3.07.
01-15-2012, 12:48 AM | #3 |
60-66 Nut
I believe the truck 12 bolts had a 3.07 ratio, and the passenger car 12 bolts had a 3.08 ratio. Those two numbers get swapped around during conversations frequently.
01-15-2012, 01:31 AM | #4 |
I gave up on changing my 4:56 axle in my '65 C20 over to a 14 bolt, don't mean to hijack your thread. I decided to just change the ratio, although I have heard 4:11 is the best I can do?
01-15-2012, 06:42 AM | #5 |
Yes I checked and my rear end is defently a GM 12 bolt, the 307 gears work out just right for the road.
01-15-2012, 11:29 AM | #6 |
Truck 12 bolts came in both ratios for some weird reason, and the 14 bolt (73-2000) can be had with gears as tall as 3.23.
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) |
01-15-2012, 03:13 PM | #7 |
"Where were you in '62?"
1960-1966 Chevy/GMC Pickup Truck Specs & Engine/Trans/Axle ID's
http://67-72chevytrucks.com/vboard/s...d.php?t=327764
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-15-2012, 05:22 PM | #8 |
Hey, PureBred, with the 3.07 gearset, what engine & tranny do you have and what is your engine RPM @ 60 mph?
I have 3.73 in my 1966 C-10. 283 and 4spd SM420 tranny @ 60 = 2800 rpm or so. This doesn't get much highway use, due to the high rpms. Back country roads and secondary highways are best.
Eugene, Oregon Lucy's Limousine 1966 C-10 LWB 283 w/ 2bbl, OE carb and dist. 4 spd (granny 1st) w/ 3.73 rear end |
01-15-2012, 08:14 PM | #9 |
I have a 350 with a turbo 350 trans, at 60 about 2100.
01-16-2012, 12:18 AM | #10 |
60-66 Nut
What size rear tires are you running?
01-16-2012, 03:50 PM | #11 |
Learn something new everyday.
