04-26-2003, 06:29 PM | #1 |
differential gasket...anyone use silicone?
I am going to do my differential cover gasket over (leaking) and valve pan gaskets. I can find the valve pan gasket but not the differential gasket. A guy at the parts store said to just use a good grade of silicone since it isn't a high heat area and it will hold up. Anyone tried?
Thanks, Dave
Dave Benamati Hughesville, PA USA |
04-26-2003, 06:43 PM | #2 |
That's what I use...I think it was the red rtv or something like that...no leaks at all.
04-26-2003, 08:15 PM | #3 |
Robert Olson Transport
ive used silicone too just make sure that both the cover and the differential are good and clean before ya silicone it with the permatex hi temp silicone gasket maker and sealant
04-26-2003, 09:03 PM | #4 |
...used silcone many times get the ultra black...best damn silcone i've ever seen for sealing anything with oil....fixed my work boot with it once too...lol...
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
04-27-2003, 01:16 AM | #5 |
I second Mooneyes4by's suggestion. Works great and it matches the color of the axle, too.
'72 C/10 LWB 402/400 Blaine, MN |
04-27-2003, 02:26 AM | #6 |
Recovering Truck Driver
heck, till I started looking for rear end parts for my convertible, I didn't even know they made a gasket for rear diff covers......lmao
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-27-2003, 02:29 AM | #7 |
" SHOW ME"
yeah im goin with mooneys they all work good but that ultra black out performs any thing ive ever used
04-27-2003, 03:22 PM | #8 |
its all about the +6 inches
I got mine glued on too...been 2 years no problems. I think it is the only part of my truck that does not leak. (knock on woodgrain)
04-27-2003, 06:52 PM | #9 |
every article I ever read in hot rod and truck magazines never used the gaskets, always silicone. I never had problems with the silicone on any of my cars. just clean the two surfaces well.
Displaced Canadian in Monterey California 1970 K10, 350 HEI, 4spd. 3.73's NP205 33"BFG Mud Terrains Edelbrock Intake and carb. 12 bolt rear,dana 44 front with disk brakes |
04-27-2003, 07:17 PM | #10 |
Born Psycho
on most new trucks you can't even buy a differential gasket, they all use silicone. as stated before, use the ultra black and make sure both surfaces are spotless, any leftover oil residue and it will leak. we only use silicone at work and never have any problems--as long as it's cleaned properly prior to installation.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-27-2003, 07:20 PM | #11 |
68cst_ss490
Ultra black is the way to go. Just drain the diff well and make sure the surface is clean and dry. Put the silicone on the cover being sure to make a circle around each bolt hole and then put it on.
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
