03-06-2012, 01:36 PM | #1 |
Cowl to Hood Gap!
I have everything fitted and painted. Lines look great all over until I installed the cowl. Installed the cowl and got it lining up good and close the hood and notice a close to 1/2 gap between the hood and cowl. The gap between the hood and grill is great. Any ideas on what to do?
03-06-2012, 02:15 PM | #2 |
Re: Cowl to Hood Gap!
If the lines of the cowl line up with the back of the fenders were they meet the doors have a good even gap then about all you can do is slide thee hood back a little to split the difference.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
03-06-2012, 04:48 PM | #3 |
Install your hood to cowl seal that the factory used in that location for the gap and you should be good to go.
Paul Jr @ GMCPauls |
03-06-2012, 05:34 PM | #4 |
I have found that if you loosen the front bolt on the hood hinge where it attaches to the fender, and raise the hinge a little, it will close that gap. And yes, you will have to re-adjust the rear also.
I know that there should be some spring(for a lack of a better term) when you pop the hood latch, how much I'm not quite sure. |
