03-09-2012, 08:37 PM | #1 |
bed mounting 51, hidden bolts?
just tore all my old bed apart, and cant use any of it exc except the 3 cross sills...
Anyone use the hidden bolt strips? if so,,,how did you mount the bed to the frame? since there are none that go through the wood.. did you just use short bolts and bolt the cross sills to the frame, reached from under the bed? would that be possible even if you used bolt showing wood strips? |
03-09-2012, 11:20 PM | #2 |
Re: bed mounting 51, hidden bolts?
You bolt the bed down first then place the wood.
You will need to releive the wood in 4 spots where the head if the carriage bolts interfer with the wood.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-10-2012, 01:14 AM | #3 |
I used strip bolts but hidden bed bolts. Just bolt your cross sills to the frame and a relief for the head in the bed wood (or in my case bed plastic) I used trex plastic decking.
Go to boltdeopot.com to buy ss bolts in boxes of 100 for a lot less than the bolt kits Posted via Mobile Device
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-10-2012, 01:17 AM | #4 |
Notice that I also used standard angle iron on my bed sides
03-10-2012, 09:57 AM | #5 |
bolt the bed first, u should have a box on each corner over the frame, use shorter bolts, then get u a strait edge of some kind that will go from front cross seal to rear cross seal, then mount your cross seals, its easy an it looks alot better
