Old 03-28-2012, 02:04 PM   #1
socalkevin68
socalkevin68's Avatar
Question Lowering Coil Spring Rear Question!
Hey guys...i really want to lower my 68 c10...it has coils all around and is very stock...sits too high for me...a few inches higher in rear and lots of room between fender and wheel top..
Anyhow..I want to start by bringing the rear down as it will be easiest...
I'm wondering what size lowering spring (1,2,3 etc...) I should put on rear to kinda bring it so she sits level?
Eventually i want to lower front..but don't really have the money to do 2 in drop spindles and disc brake swap at the moment..and i really dont want lowering springs alone on the front as i've hard its hard to align etc.
any input is much appreciated..thx
socalkevin68 is offline   Reply With Quote
Old 03-28-2012, 02:12 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lowering Coil Spring Rear Question!
What size wheels are you running? If you have larger than 15's I suggest a 2" block and add the lowering spring as needed. If you are running 15's then a 1.5" block will prevent scrubline concerns.
For the front you can cut 1 coil off of the stock spring for an economical drop. I would recommend an alignment with any changes you make in the front suspension.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-28-2012, 02:16 PM   #3
Pro Performance
Pro Performance's Avatar
The best way, is to get the lowering springs you plan to go with in the end, as it will save you money and keep you from buying springs again to go lower more to match the front when you do it. What are your plans for the truck? Do you eventually want to have a 4"-6" drop?
We carry the Hotchkis springs for the rear that drop it 6". That might be too much for now, but once you get the front spindles / springs, etc, it will be right on. Another option is doing the 4"-6" drop kit altogether from the start. Just some options....
Spindles are a slightly better route to go when lowering, but Hotckis has had good results with their 4" drop springs.
Rear 6" Springs
4"-6" Drop Kit
Travis
Pro Performance is offline   Reply With Quote
Old 03-28-2012, 02:17 PM   #4
Pro Performance
Yes, this is also a good option as well until you decide your plan exactly. Then, once your'e ready to do it all, you can replace with drop coils, etc.
Thanks Ken!
Old 03-28-2012, 03:01 PM   #5
socalkevin68
i have 235/70/15's all the way around on rallys....
Can you guys tell me more about how to drop rear with blocks? and where i can buy them...etc...thx...
Old 03-28-2012, 06:26 PM   #6
Pro Performance
You should be able to get the drop block at your local auto parts.
Old 03-28-2012, 06:57 PM   #7
socalkevin68
hey Street3285....If i get the kit you showed me 4/6 drop with just springs..how will my truck ride...will it be align "able" with just lowering springs?
thx
Old 03-28-2012, 07:24 PM   #8
Pro Performance
It will still ride well.... maybe a little firmer due to the spring rate, but your truck will handle better. That kit will come with new bump stops for the front, and you won't have any issues aligning the truck. It is all made to work on that truck without issues.
Travis
Old 03-28-2012, 07:29 PM   #9
socalkevin68
will i need different shocks and panhard bar if i do the 4/6 drop?
Old 03-28-2012, 07:38 PM   #10
Pro Performance
You can use the stock panhard bar, but yes, new shocks will be needed as much shorter ones are required.
PM Sent
Old 03-28-2012, 08:00 PM   #11
socalkevin68
hmm sounds great...500 to do a 4/6 ...complete with shocks? ..since I cant really afford the drop spindle/disc bbrake swap..and this truck is only used to cruise around town now and then...i'm thinking this is the route i'm gona go...
Anyone do this 4/6 hotchkis drop on their truck? If so any pix or what you think of it...would be greatly appreciated...
I know most guys say go spindles..but i rly cant affor that route now.....
thx
Old 03-28-2012, 08:09 PM   #12
Pro Performance
Here is a truck they did with a 4/6 drop. 18" wheels all around.
Old 03-28-2012, 08:16 PM   #13
socalkevin68
nice..same color as my 68..(except my paints 40 + years old) .....love them wheels too..i have 15x8 rallys...i think will look ok once dropped!
Old 03-29-2012, 12:10 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
I have never run Hotchkis products, but I can say I have never heard anything bad about them. I think everyone will tell you they are upper tier suspension components.
Articles-
"Refining Sierra"
Old 03-29-2012, 03:34 PM   #15
cdowns
cdowns's Avatar
if you just use springs to lower rear without getting adjustable panhard bar the rearend will b offset and can cause clearance problems with tires//also a 6" drop in the rear may require shortening driiveshaft and angle shim for pinion angle
Old 03-31-2012, 06:53 PM   #16
shawno72
C/10 junkie
shawno72's Avatar
What is a good pinion angle for a truck with 5" drop springs and 1" blocks?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 03-31-2012, 08:15 PM   #17
Lower
Lower's Avatar
I've got 6" rear springs and the pinion angle was fine, drive shaft didn't have any length issues either.
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 04-01-2012, 06:53 PM   #18
Pro Performance
You should be good. I have always understood that the pinion angle on the rearend, should be at the same angle as the transmission.
Old 04-01-2012, 08:10 PM   #19
shawno72
C/10 junkie
shawno72's Avatar
Ok thank you. I will be swapp
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-01-2012, 08:11 PM   #20
shawno72
C/10 junkie
shawno72's Avatar
Ok thank you. I will be swapping in a new rear end and just want to make sure I get the pinion angle right. Putting the rear parallel to the trans makes sense.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 05-16-2014, 09:49 PM   #21
1970customhugger
Is there anyway you could find out what wheels, size, and offset and size tire this truck has?
1970 C10 ls3
1972 GMC Suburban ls1/60e
1972 c10 swb
1972 GMC Sierra swb
1970customhugger is offline   Reply With Quote
Old 05-17-2014, 02:34 AM   #22
NEWBIEC10
NEWBIEC10's Avatar
I'm new to all the 2wd and Chevy thing. But I cut 1.75 coils out of the front. And built lowering blocks for the rear and had U bolts made for $14.95 pair at a local 4x4 shop. Which = out to be a 4/2 drop. I recently got Jeep wrangler springs for free from the same shop that made my U bolts and that should give me another 4" in the rear. So all in all for a 4/6 drop I'm into it $15 and a few Rainier Beers and some time well spent in the garage.
By the way after cutting the front springs I had my alignment check from a friend at a local tire store. And the truck was perfect. I'm also running 15" Stock wheels with 235x75.
NEWBIEC10 is offline   Reply With Quote
Old 05-17-2014, 02:45 AM   #23
NEWBIEC10
NEWBIEC10's Avatar
235x70 tires. Sorry
Also here's a photo as it sits with the 4/2 drop. I will post a picture of it with the jeep springs after Memorial Day weekend.
Old 05-17-2014, 02:49 AM   #24
NEWBIEC10
NEWBIEC10's Avatar
Originally Posted by NEWBIEC10 View Post
235x70 tires. Sorry
Another photo.
Old 10-08-2015, 06:21 PM   #25
ReidCagle
x2
ReidCagle is offline   Reply With Quote
