Hello to everyone out there. It's about time the weather is getting better.
I'm looking to change my short water pump on my 72 Chevy C10 350. Would I be able to put a long water pump on instead? If so, is one better than the other? Thank you, George |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: short or long water pump
The long water pump requires different pulleys, P/S brackets, A/C brackets, and alt. brackets.
Totally different set-up.
Hi Keith, thank you so much for that information. I had no idea I would have to go through something like that. I'll just stick with the short water pump and save myself money and a headache. Thanks again Keith and have a great weekend, George
Keith, I'm not sure what the difference is between a High Volume water pump and a regular pump. Would you know? Thanks, George
Better cooling maybe?
I like the Edelbrock aluminum water pumps.
Ok, thanks Keith. Have a good one.
Gone Fishing
The high volume ones are suppose to move more water through the system
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
Thank you very much for that info. I appreciate it.
