Old 05-03-2012, 08:14 PM   #1
chewychevy67
oil bath breather restoration? new filter hair available?
I pulled out the horse hair (I think that is what it is) in my oil bath breather so i could have it powdercoated and was wondering if anyone else has ever done this and what did you use in place of it? I did keep the old stuff but it looks fairly dirty and when i removed it the hair broke down into small pieces that the engine may suck up now. is there maby a special foam or replacement hair to make it like new again? Rod.
chewychevy67 is offline   Reply With Quote
Old 05-04-2012, 09:05 PM   #2
chewychevy67
Re: oil bath breather restoration? new filter hair available?
Some small engines have a kind of foam air cleaner i think. Anyone have any ideas?
Old 05-04-2012, 10:32 PM   #3
lil hoodlum
lil hoodlum's Avatar
I was thinking foam as well. I'm sorry, other than that, I wouldn't have a clue what else you could try.
Keith
lil hoodlum is offline   Reply With Quote
Old 05-04-2012, 10:51 PM   #4
chewychevy67
I wonder what kind of foam to use? Where to look for it?
Old 05-04-2012, 11:49 PM   #5
MagmaJct
MagmaJct's Avatar
I've heard in VW forums that stuff is coir.
http://en.wikipedia.org/wiki/Coconut#Coir
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback.
The C10 and the Super Beetle run, the Fastback is just not there yet!
Please visit my Super Beetle and Fastback profile on TheSamba.
MagmaJct is offline   Reply With Quote
Old 05-04-2012, 11:50 PM   #6
MagmaJct
MagmaJct's Avatar
http://en.wikipedia.org/wiki/Coir
Old 05-05-2012, 03:21 AM   #7
Willys47
Willys47's Avatar
would a steel whool work for a replace meant. some ss stuff like a pot scrubber is what I was thinking of ?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-05-2012, 03:51 PM   #8
chewychevy67
you can buy a roll of stainless steel wool. it is packed fairly tight and would be hard to get back in there but might work. similar to pot scrubbers. is there a certain air flow cfm or something that an air cleaner needs so the engine breathes good?
Old 05-05-2012, 04:03 PM   #9
chewychevy67
stailness steel
http://www.ebay.com/itm/Stainless-St...item483f15152d
what do you guys think. I would think tht this would not be flamable but would try burnbing a small spot before using it.
Old 05-05-2012, 04:05 PM   #10
vectorit
What?
vectorit's Avatar
This is what I use.
http://farmallparts.com/products/?vi...oduct_id=25451
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-05-2012, 05:16 PM   #11
chewychevy67
Originally Posted by vectorit View Post
nice find. did you replace yours? how did you get it back in? did you have to cut i open to slide back in place?
Old 05-05-2012, 05:41 PM   #12
vectorit
What?
vectorit's Avatar
I never took the OE fiber out.
I just soaked it in simple green, then rinsed it clean.
The metal mesh I use as noted above, is what I put it the oil itself and stand it on its edge around the inside of the filter. The oil wicks itself up the metal mesh, and adds extra filtration for the dust.
I don't know if this was original, but it's been that way as long as I can remember in my original set up. So I just continue to it, and I do see it helping since it does get dirty.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 05-05-2012, 07:19 PM   #13
chewychevy67
Mine had the matrial already gone so i decided to powder coat it.
Old 05-05-2012, 08:07 PM   #14
4xshort
4xshort's Avatar
Just my opinion, but I wouldnt use steel wool if you shake it alot of small pieces fall ouy of it. On the rigs we use "filter blankets" they are available at Aklands. They come in all thickness and sizes and would be available locally. Plus they are made for air filters so it would be safe. Hope that helps.
1971 Chevy shortbox 4x4 made in Canada
4xshort is offline   Reply With Quote
Old 05-05-2012, 10:48 PM   #15
chewychevy67
i will have to go check them out . thanks for the help 4xshort
Old 05-05-2012, 10:52 PM   #16
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Tractor supply company carries replacement material for oil bath air cleaners.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 05-06-2012, 12:58 AM   #17
chewychevy67
Would copper mesh work like they used on the older harleys i wonder?
Old 05-06-2012, 11:30 AM   #18
d4xycrq
Air cleaner wire mesh - still used in agricultural tractors.
http://www.just8ns.com/catalog/produ...roducts_id=522
Nine bucks.
Best regards,
Ray
d4xycrq is offline   Reply With Quote
Old 09-14-2013, 12:50 PM   #19
bhc41051
bhc41051's Avatar
Any updates ChewyChevy? I'm in the same boat, My filter has dried up horse hair. I'm afraid to use it..
bhc41051 is offline   Reply With Quote
Old 09-15-2013, 05:28 PM   #20
chewychevy67
I was thinking about this last week but haven't used anything yet. More ideas welcome.
Old 10-20-2013, 11:37 AM   #21
chewychevy67
did you decide on anything yet? I too am a little scared to use the old horse hair stuff. it is brittle and don't really want that gong through my engine.
Old 11-30-2013, 02:35 AM   #22
bhc41051
bhc41051's Avatar
Nothing yet, my project is on hold for a few months. I'm on a military deployment. I was hoping you would find a solution
Old 12-12-2013, 03:06 PM   #23
chewychevy67
I am going to use one of these. http://www.just8ns.com/catalog/8N-96...r)-(2-REQUIRED) or http://www.steinertractor.com/ABC422...th-air-cleaner. They both look the same. I am going to get this done after xmas so ill let you know how it goes.
Old 03-16-2014, 04:47 PM   #24
chewychevy67
well I got my oil bath air breather all done. First I powder coated it. Then I used this element http://www.steinertractor.com/ABC422...th-air-cleaner. I needed 4 bags. It took a little time to get it all even in the top but it worked out very nicely. Here are some pictures. just have to put the decal on it yet that member LocDoc made me and it is complete.
Old 03-22-2014, 09:14 AM   #25
bhc41051
bhc41051's Avatar
Wow, Chewy that looks fantastic! I had pretty much given up on using the oil bath. But yours looks better than new. As soon as I return from my deployment I'll give you an update.
