Old 05-05-2012, 12:23 PM   #1
gramps77
Holley throttle bracket with 700R4
Just swapped in a 700 into the 77. Is anyone using this bracket and if so, is it strong enough? http://www.holley.com/20-95.asp
I know there's a lot of tension on the TV cable.
Im running a 670 Street Avenger
gramps77 is offline   Reply With Quote
Old 05-05-2012, 12:51 PM   #2
Pro Performance
Pro Performance's Avatar
Re: Holley throttle bracket with 700R4
I used a similar bracket on my Holley, but the TV was also really tight and I couldn't get it to adjust right either. From my experience, the TV cable is supposed to barely have tension at it at idle. The truck might shift weird because the more it pulls it, it thinks you have more throttle, and will hold the shift longer at lighter throttle.
I switched to a Lokar and it was much better. Although more expensive, it was a nice piece and setup how it should be.
Pro Performance is offline   Reply With Quote
Old 05-05-2012, 12:57 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
You also need this
http://m.summitracing.com/parts/hly-20-121
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-05-2012, 01:02 PM   #4
Pro Performance
Originally Posted by INSIDIOUS '86 View Post
You also need this
Does that extend it out, so the TV cable isn't pulled to so tight? If so, I didn't know they had that.
Old 05-05-2012, 01:22 PM   #5
INSIDIOUS '86
No it gives the correct geometry for the cable so the trans shifts normal and doesn't blow
Old 05-05-2012, 02:12 PM   #6
kmfb
I have both on my holley, works like a charm and quick install
kmfb is offline   Reply With Quote
Old 05-05-2012, 03:05 PM   #7
'82 steppin
'82 steppin's Avatar
You also need this
Yup thats right I used them before and it worked great
'82 steppin is offline   Reply With Quote
Old 05-05-2012, 03:16 PM   #8
Pro Performance
Where were you guys when I was doing mine!
I knew it wouldn't shift right with it pulled so tight. Good to know on the next one.
Old 05-05-2012, 07:01 PM   #9
gramps77
I currently have Bowtie Overdrives TV kit but I was trying to find a throttle cable bracket that would work with it. Then I found the Holley one. Now that I read your replies, I'm thinking I need to just keep with their kit.
Now I'll just need a throttle bracket by itself that will work with it
Old 05-05-2012, 07:37 PM   #10
S10Fan
Old Heap Driver
I have both on my Holley Street Avenger/700r combo, no issues at all since the October 2009 install.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-06-2012, 10:16 PM   #11
crazeetxn
crazeetxn's Avatar
I have had the bracket and extender on my Holley 600 with the 700R4 and they do go hand in hand.
Haven't had any problems and that was 8 yrs ago..give or take
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 05-06-2012, 11:14 PM   #12
gramps77
Happy to report that I used http://www.holley.com/20-95.asp and the geometry is the same as the BTO TV bracket. Using BTOs bracket at the carb arm to hook up the connector from the TV cable but the throttle and TV bracket worked great.
