Old 05-27-2012, 03:31 PM   #1
Cochise
Junior Member
Cochise's Avatar
Can't figure what's going on with my truck
1970 Chevy C-10 with 350/350 out of a '72 Cheyenne. I was having trouble starting my truck back after it ran for awhile. My mechanic who works at the dealership I work walked me through the motor install and told me it was either the starter or the HEI distributor shaft may be stuck. I took the wires off the cap, looked below the rotor bug and decided since it moved freely that it was the starter. After I replaced the starter I put everything back the way I had it and would turn over fast, but wouldn't start. I pulled the cap back off and noticed that I pointed the rotor at number 1, but for points, so I went to TDC, raised dist shaft and pointed at number 1 for HEI, put it all together and I either get a huge backfire (at midnight) or I get fire through carb. I have checked the firing order 8 times to be sure and clockwise.
1. I am not positive that the 3 pin wire on the Dist is plugged all the way in, could that be?
2. What else could it be?
Cochise is offline   Reply With Quote
Old 05-27-2012, 03:36 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Can't figure what's going on with my truck
Backfire through the carb is timing. A valve is still open during a combustion cycle. You need to find TDC again, and set your rotor to point either straight ahead or at the #1 cylinder... it really doesn't matter as long as the #1 plug terminal on the cap is relative to where you set your pointer.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-27-2012, 04:05 PM   #3
Cochise
Junior Member
Cochise's Avatar
Do I have to bump it, or can I manually move it?
Old 05-27-2012, 04:08 PM   #4
snacks
snacks's Avatar
what he said find tdc ,where the rotor is pointing is 1 start from there as long as your not 180 out rotor should be in the 3 4 or 5 oclock position,
snacks is offline   Reply With Quote
Old 05-27-2012, 04:31 PM   #5
Cochise
Junior Member
Cochise's Avatar
It sounds like from what everybody is saying that I have done everything right, except maybe I AM 180 out. I didn't bump to TDC, I just turned it to TDC by turning it by hand, could that be it?
Old 05-27-2012, 04:54 PM   #6
Mcnasty
Make darn sure you're TDC on compression stroke on #1 cylinder!!! You can do this by putting your finger firmly over the spark plug hole to create a seal then rotate the motor by hand. Listen for the "hiss". Start from there.
Mcnasty is offline   Reply With Quote
Old 05-27-2012, 05:01 PM   #7
Cochise
Junior Member
Cochise's Avatar
Yep, did that too, still didn't work, but I'll try to do it again tonight
Old 05-27-2012, 10:48 PM   #8
Cochise
Junior Member
Cochise's Avatar
Thank you very much for your help....by turning it by hand I wasn't able to really hear the pssh, even by turning it by hand with a ratchet. I had my wife bump it and it ended up pointing at 1 o'clock I moved it and reset it and he fired up after a little walking around with the timing....now I can sleep
Old 05-28-2012, 09:20 AM   #9
GASoline71
GASoline71's Avatar
Good deal. Sounds like you were possibly bringing it up on the exhaust stroke. Now that she's on the compression stroke... all is good.
Gary
Old 05-28-2012, 11:16 AM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Don't know about your engine, but remember the harmonic balancer has a rubber piece between the inner and outer parts....and, that the outer ring can shift over the years and what you think is TDC according to the timing marks, is actually off. Some engines are more prone to this than others, it seems. I'm not saying yours has such a problem, but there may be someone here who is new and didn't know that fact.
Those of us who grew up with points and condensor ignition systems have forgotten about some of the "finer points" that we learned at the time. OBDII is a wonderful thing, but some old school learning is still good.
I've seen people blame the carb for your problem, and then spend money that they didn't need to when the issue was as simple as yours was.
Member Nr. 2770
