Old 05-28-2012, 12:54 AM   #1
Frijolito1988
Door sideview Mirros
Hey guys, I just bough some side view mirros for my truck, got the base and the actual mirror. My truck does not have any holes so i was wondering if anybody could post pics of their base to check where I should mount the base exactly. Or does anybody know the exact measurements as to where to drill the holes ? Thanks.
Frijolito1988 is offline   Reply With Quote
Old 05-28-2012, 12:59 AM   #2
67c10rustbuket
67c10rustbuket's Avatar
Re: Door sideview Mirros
Depends on year and which mirrors, which ones did you get and what year truck?
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-28-2012, 10:31 AM   #3
ole dollor
ole dollor's Avatar
fri 1988: set in your truck and have someone hold the mirrors to where you can see the best, if you are alone, tape them to the door and set in the truck and move them around until you can see out of them ,then you can mark and drill your holes....
ole dollor is offline   Reply With Quote
Old 05-28-2012, 10:55 AM   #4
Boog
laying low
Boog's Avatar
Once taped in place you will need to open the vent window to see that it swings fully without hitting the mirror.
Somebody once posted measurements for the sport mirrors to locate them correctly. Maybe they'll post them again.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-28-2012, 11:04 AM   #5
Frijolito1988
Thank you for the replys guys! I will try that out today. This is the type i got.
Uploaded with ImageShack.us
Old 05-28-2012, 11:07 AM   #6
ole dollor
ole dollor's Avatar
fri 1988 thats the ones i like to....looks good and dont catch a lot of wind...
Old 05-28-2012, 11:13 AM   #7
Daddy Brim
Daddy Brim's Avatar
It depends on the mirror. It sounds like you are using the one with 3 holes. When I put one on the right side of mine, I took a piece of paper and traced the holes and body line around top corner and then reversed to other side. IF you need I can take pics of mirror arm with measurement.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 05-28-2012, 08:43 PM   #8
67c10rustbuket
here are a few measurements to help you out with those '67-'68 stlye mirrors
From the front door edge (driver side pic'd)
as measured with tape between the holes. Note-if you measure above the hole locations the slope of the door edge will move your measurements. so hold the tape with the top of the tape measure 1" from the body line. little confusing but these should get you real close.
hole 1- 2.75"
hole 2- 4.625"
hole 3- 6.375"
Lower of the three- 1.75" from upper body line
Dan <---(my name)
